NAME THAT NOISE???????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 81jimmyslt, Oct 8, 2003.
  1. 81jimmyslt
    81jimmyslt 1/2 ton status
    Jun 5, 2003
    1,643
    So Lake Tahoe (Rubicon), CA
    Ok guys I know this can be hard but I just need more ideas of what can be wrong before I start replacing things.
    When I am driving about 18-25mph and start coasting I get this loud screeching rotaional noise coming from the driver side. This is the only time I hear it. /forums/images/graemlins/ears.gif its real LOUD! /forums/images/graemlins/eek.gif
    Rea uh rea uh rea uh
    It's driving me nuts, I'm going to jack the truck up and start playing with each corner for now. The only thing I've come up with is Rear axle u-joint or front, my friend thinks it might be an axle bearing??????
    Any Ideas?????? /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/confused.gif /forums/images/graemlins/angryfire.gif
  2. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I'll take a stab at the t case end u joint. May not be any bearings left. Crawl under and start takin' stuff apart.
    John
  3. Okiemuddog
    Okiemuddog 1/2 ton status
    Mar 3, 2003
    1,260
    Guthrie, Oklahoma
    try pulling each drive shaft and drive it around the block or something, that will eliminate the driveshaft as being the problem. It sounds to me like a brake, a wheel bearing will cause bad vibrations, if you have a brake that is glazed or wore down to the squeaker that would cause the same problem. A front wheel bearing will usually cause a groaning sound all the time. U-joints will usaully squeak all the time and vibrate too. Just my 2 cents. hope that helps and good luck.
    Krennen
  4. 81jimmyslt
    Jun 5, 2003
    1,643
    I'm pretty sure it's not a u-joint have change many of those. Still a possibility though and I changed my front wheelbearings last summer. ALthough there could be something wrong with them still. ?????????????????? /forums/images/graemlins/confused.gif
    Any other ideas???? /forums/images/graemlins/1zhelp.gif
  5. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Yea now this is what i like lets play Vegas on who guesse it /forums/images/graemlins/rotfl.gif
    any ways my $$ goes on the rear end how much play - slop ya got in the shaft when its sitten still ??
    next what rear end are ya running how many miles
    next remove the rear dif cover and see how much play ya have in the center pin that holds the spiders in
    there Should be NONE well les then 1/32" that is were i think your problem lies the coasting reverses the forces n the carrier hope that makes sense
    best of luck 2 ya
    and ya Better let us know what it turns out to be /forums/images/graemlins/thumb.gif
    R
  6. 81jimmyslt
    Jun 5, 2003
    1,643
    I have a 12bolt out back, with over 200,000 miles on it /forums/images/graemlins/shocked.gif that's not good. This is what I don't want to hear /forums/images/graemlins/ears.gif I guess it's that time though. I was trying to delay any axle $$$ until after the engine but it looks like the truck might be seeing 1 ton sooner than expected. /forums/images/graemlins/thinking.gif
  7. Chris_T
    Chris_T 1/2 ton status
    Mar 17, 2001
    718
    Saskatoon, SK
    If I had to guess it would be a wheel bearing - possiblt overtightened when replaced. My brother had a car that sounded something like what you described.
  8. nc87k5
    nc87k5 3/4 ton status
    Sep 23, 2003
    5,231
    North Carolina
    it would be cheaper to check the brakes /forums/images/graemlins/grin.gif first.
  9. 81jimmyslt
    Jun 5, 2003
    1,643
    Ok so I borrowed a torque wrench, jacked up the /forums/images/graemlins/k5.gif and took the front passenger tire off and the whole rotor has about a quater inch play in it /forums/images/graemlins/shocked.gif When I had the tire in the air It had a lot of play and kind of made some noise.
    good trouble shooting chris and others.
    to double check would this play would mean the wheel bearing right????? /forums/images/graemlins/confused.gif
  10. uglychevyZZ4
    uglychevyZZ4 3/4 ton status
    Apr 26, 2002
    6,094
    Black Diamond, Wa
    [/ QUOTE ]maybe could be a u joint screaming like its <font color="white"> BRB's sheep in heat </font> dry, needing to be greased like <font color="white"> BRB's schlong </font> badly. or possibly the belts are recieving too much slack when you lett off the gas <font color="white"> like BRB laying down on a goat </font> but prolly the u joint dry /forums/images/graemlins/confused.gifId say start greasing good <font color="pink"> BUBBA cuz here comes the bull </font>
    /forums/images/graemlins/thumb.gifgood luck
  11. 99firehawk
    99firehawk 1/2 ton status
    Dec 15, 2002
    491
    As long as when you move your rotor top to bottom, your not moving some really worn out balljoints, or side to side, real worn tie rods.
  12. 81jimmyslt
    Jun 5, 2003
    1,643
    Ok guys so I got the tools and parts I needed (Kragen sux)
    I started taking the right front wheel of etc. When I was pulling pieces out I got to the adjusting nuts to find out they were so loose I just used a screwdriver to unscrew it. After this I checked the wheel bearings and decided there was no damage. /forums/images/graemlins/cool.gif So I Put everything back together retorqued everything1!! /forums/images/graemlins/grin.gif
    When I had the tire back on and in the air I tried shaking it as before no movement...and tire spins /forums/images/graemlins/cool.gif
    anyways took for test drive and the loud screeching is /forums/images/graemlins/ears.gif is gone
    Thanx for all the advice guys. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
