name that noise
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 87BrnRsd, Feb 24, 2004.
  1. 87BrnRsd
    87BrnRsd 1/2 ton status
    Apr 21, 2003
    2,457
    Boone, North Carolina
    i have a 79 k5 that has some type of roaring noise coming from the front end. I have replaced every wheel bearing and even the universal joint right at the diff but it has had no effect on the noise. i was wondering what suggestions you guys could come up with. i am still crossing my fingers for a solution before i crack open the diff and inspect the bearings. By the way it is a 30 spline 10 bolt but i am not sure on the year because it is a swap.
    thanks-
    Elliott
  2. BlazerGuy
    BlazerGuy 3/4 ton status
    Apr 20, 2000
    9,206
    abcde
    Do you have auto hubs?
  3. 85scottsdale
    85scottsdale 1/2 ton status
    Dec 22, 2003
    283
    Lewisville, NC
    Is it full-time 4wd? I assume it is being that year. Sounds like carrier bearings to me. If you have hubs in the front and have them un-locked then that rules that out. But full-time front end always have the axles turning and usually roaring sounds indicated bad bearings and that usually means carrier bearings.
  4. JIM88K5
    JIM88K5 1/2 ton status
    Apr 27, 2001
    1,384
    Vancouver, Wa
    Fan clutch locked up ? /forums/images/graemlins/dunno.gif
