Name these two parts
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MOABDADC22, Sep 3, 2003.
  1. MOABDADC22
    MOABDADC22 1/2 ton status
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    I am putting my 86 K5 back together and I found two parts that look very foreign to me.
    The first is a wire harness about 8-10" in length. I found out that the one end plugs into the harness in the engine compartment on the drivers side, but I am clueless as to where the other end goes. Here are two pics. The first is the wire plugged in the harness and the second is just the wires. [​IMG] [​IMG]
    The other part was in a box with about a million other pieces that came with the K5. I have never seen this part before on anything. The pic shows the front of the unknown item. On the back is a male electrical connector that something plugs into.
    This is on an 86 GMC Jimmy that does not have an ECM or ABS. Any help would be greatly appreciated. /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  2. BigOrange90Jimmy
    BigOrange90Jimmy 1/2 ton status Premium Member
    May 24, 2002
    2,923
    Wilmington, NC
    cruise control
  3. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    cruise control
    Thanks, I spaced that out. I need to locate the rest of the cruise control parts. (I only have the wires........)
    Anything on the second part?
  4. Batmanjr
    Batmanjr 1/2 ton status
    Mar 23, 2001
    1,537
    Copperas Cove, Texas
    IF I had to guess, the second part resembles a th400 electric kick down switch! Do you have a th400 in the truck? Does it kick down on it's own when you floor it? If not, There's why.... If so, Look under the dash by the fuel peddle and see if there's another one there.... If you don't have a th400, did your truck at one time? /forums/images/graemlins/thinking.gif /forums/images/graemlins/thumb.gif
  5. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    Yes, it does have a Th400 (now). I will have to look for the harness and everything else that goes along with it. Thanks for the help. /forums/images/graemlins/thumb.gif
  6. Batmanjr
    Mar 23, 2001
    1,537
    It should be a two prong wire, one end goes to a power source and the other runs to the tranny and hooks to a single connector I believe on the left side of the tranny.... I believe it was covered very well here:
    Tranny kick down switch post....
    Enjoy! /forums/images/graemlins/thumb.gif
  7. MOABDADC22
    Jul 24, 2001
    1,348
    Cheyenne, Wy
    You guys kick a$$. Problem solved and new wires have been run. Now I have to round up some cruise control pieces.
    Thanks again.
    See Bluebies...it pays to be a member. Join up!!!!!!!!
