Name this locker....
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazen91, Aug 9, 2001.
  1. blazen91
    blazen91 1/2 ton status
    Sep 10, 2000
    1,738
    Hesperia, Ca 92345
    It has spider gears and some beefy springs. No little gov lock gears inside. Not alot of info, any ideas? Pics will help.
    <font color=red>Land use issues are the heart of our sport.
    Get involved or lose the sport.</font color=red>
  2. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    GM posi!
    Tim
  3. Twiz
    Twiz 1/2 ton status
    Mar 8, 2001
    3,729
    Clearfield Ut.
    Standared limited slip. There should also be some clutch packs behind the side gears. What diff is this? What year?
    Regadless, The springs preload the clutch packs to (for example) 300 ft/lbs, past that, the axle shafts will slip past each other. They do wear-out, and the pre-load "loosens" up. But thats the genneral idea.
    Twiztid
    This is all about opinions, and this is mine. (if applicible)
    Opps, not ft/lbs, it should have been, lbs per sq inch.<P ID="edit"><FONT class="small">Edited by Twiztid on 08/09/01 10:30 PM.</FONT></P>
  4. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    I ain't got the slightest idea! Good luck.
    Stuck is a state of mind!
    Mudstud
    76K5 sb400/350/203parttime/3.73-D44/GM12 locked
