Name this Posi Unit
Discussion in 'The Garage' started by mountainexplorer, Dec 16, 2006.
  1. mountainexplorer
    mountainexplorer 1/2 ton status
    Nov 14, 2001
    4,903
    Spokane, Wa./Ione, Wa
    I was pleasantly surprised to find the '91 GMC Crew Cab I got had a Detroit Locker in the 14-bolt rear. The front 60 has spider gears but looks like clutches on the sides.
    Who can name what sort of Posi this is? (Pictures attached)
  2. JEBSR
    JEBSR 1/2 ton status
    Dec 23, 2004
    1,541
    Clarksville, TN
    Thats what was in my 60 when I bought it, looks like an eaton unit to me but from what I can gather on the net Dana/Spicer makes it.
  3. walla2k5
    walla2k5 1/2 ton status
    Sep 5, 2004
    2,054
    Walla Walla, WA
    I had one like that on a 44. I think it's called a Trac-Loc or something.
  4. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Yep thats a Trac-lok.
  5. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
  6. thatK30guy
    Jan 12, 2001
    32,076
    55
  7. mountainexplorer
    Nov 14, 2001
    4,903
    It's a 3.73 ratio front. I'm thinking use it for my snow plow truck which won't run larger than 33" tires. I'm thinking turning 36-40" tires wouldn't be the best for a Trac Lock
  8. thatK30guy
    Jan 12, 2001
    32,076
    55
    At least with that ratio, you can actually DRIVE it on freeway speeds.....
  9. mountainexplorer
    Nov 14, 2001
    4,903
    yeah, if it was a stronger posi unit I was thinking of having to swap gears and all that to run it in one of the bigger trucks. But beings that it's 3.73's and already set up, I could swap it into my plow truck which is just a frame sitting here anyways.
    But the matching 3.73 rear has a Detroit which I'd rather not run with the plow truck. The current rear end is a Gov-Lok with 4.10s... I wonder if I could just switch ring and pinions... carrier's the same in a 14-bolt between 3.73 and 4.10 if I remember right... so I could put the 3.73 rear ring and pinion onto the current Gov Lok carrier and use the matched 3.73s in the plow truck, which would be a 454/TH400/205 and 33" tires or 235/85R16 studded snows in the winter.
  10. K5MONSTERCHEV
    Jan 27, 2003
    3,254
    Castro Valley, CA
    Thats actuallty intresting to see a 60 front with a trac-lok instead of a powr-lok.
    The problem with the trac-loks is that they break clutches, but im talking about in a rwd vehicle with 70K plus miles on it, such as Dodges with a 9 1/4" rear end. You'r 36's should be fine.
  11. mountainexplorer
    Nov 14, 2001
    4,903
    It's probably not worth the hassle to tear it all apart and swap gears in it to run the Trac Loc in one of the trucks with bigger tires. I'd probably have to run 4.10s to be able to use the same carrier, or have to buy thick cut gears.
    And I'd probably find a way to break it with larger tires.
