napa 447 u-joint doesn't fit
Discussion in 'The Garage' started by slimlynn1, Nov 15, 2003.
  1. slimlynn1
    slimlynn1 1/2 ton status
    Apr 9, 2003
    336
    Hamden, CT
    napa 447 u-joint doesn\'t fit
    I just went to put my Napa 447 u-joint in and it doesn't fit. the inner snap rings should be 2.556" but they are more like 2.656". Has anyone run into this problem. I also have some car quest u-joints 2-3011 with the same measurments. What is wrong? Any help would be great.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: napa 447 u-joint doesn\'t fit
    The 12 bolt (1310) to 14 bolt (1350) is Napa number 348
    The 10 bolt (1330) to 14 bolt (1350) is Napa number 447
    That work for ya?
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    take the axle side caps off your old ujoint and put them on the 447...
  4. Fry
    Fry 1/2 ton status
    Sep 5, 2002
    400
    Sask, Canada
    Thats not always true... 1330 is for internal lock rings, 1310 is for external. I found this out when I was doing my axle swap. My 10 bolt driveshaft took a 1310 and the 14 bolt took a 1350, so I got a 1310/1350 Cross. I picked up a 1330/1350 Cross first after I read on here then noticed the internal lock rings which wouldn't work.
  5. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    napa447 didnt work for me either. I took my old caps and the caps from the 447 that fit the 14bolt and got the correct one.. I ended up getting it at carquest... but unfortunalty I cant find the part number.
  6. BowtieRed
    Dec 31, 2002
    1,776
    Winston-Salem, NC
    That work for ya?
    hmm. . . i think i mighta said that/forums/images/graemlins/rotfl.gif
  7. Fubeca
    Fubeca 1/2 ton status
    Dec 18, 2002
    2,100
    Denver Area
    Many 10B had the gm 3R or something like that not the spicer 1300 series. It is probably not a 1310 or a 1330 but the gm part number instead.
  8. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    As far as I know it should be a Saginaw 44, which is what the napa 447 is. It should fit but it doesn't. I will try it with the old caps.
  9. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yes, it is a saginaw S44.
    Neapco part number 2-1153 will get ya an S44-1350 joint. 3-3140 is a 1310 to 1350 for all you other guys.
    2-3011 is just a saginaw S44 joint, not a conversion to put in a 14 bolt. That's why it doesn't fit the yoke on the 14.
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Whatever is not fitting, explain it better. What is too big or too small, the caps or the cross?
  11. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    The cap diameter is fine but the distance between the internal locking clips on the u-joint does not match the yoke. The yoke is about 2.53 inches inside and the u-joint is 2.656 inches clip to clip. So I can not get the second clip on the u-joint.
  12. TSGB
    TSGB 1 ton status
    Apr 22, 2002
    12,527
    Centralia, Washington
    It's the other way around for my Ford. Have a hell of a time finding my joints anywhere BUT napa.
  13. kennyw
    kennyw N9PHW Premium Member
    Jun 9, 2002
    13,223
    94
    Stevens Pass Highway, WA
    The 10 bolt (SAGINAW 44) to 14 bolt (1350) is Napa number 447
  14. kennyw
    Jun 9, 2002
    13,223
    94
    Look into the NAPA 372. I had to use this to convert from a 12 bolt to a 14 bolt SF.
    My experience
  15. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    Fixed it! I went out and got a Precision 447 u-joint and it fit perfectly. I dont understand it, it should be the same joint but it is not. It's a little different!
  16. 83ZZ502_Jimmy
    83ZZ502_Jimmy 1/2 ton status
    Feb 7, 2001
    3,103
    Richmond, VA
    Glad you got it figured out. I know how frustrating u-joints can be. /forums/images/graemlins/smile.gif
    John
  17. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Could be (i've had this happen before) that the first one you got was actually the wrong u-joint in the box /forums/images/graemlins/shocked.gif
  18. slimlynn1
    Apr 9, 2003
    336
    Hamden, CT
    Thats what I thaught so I actually got a second NAPA 447 u-joiont and compared them. They were identical to each other.
  19. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    John
    Is that why you have a Neapco catalog? I never have it further than arms reach from me when I am posting on CK5. /forums/images/graemlins/smile.gif
  20. 83ZZ502_Jimmy
    Feb 7, 2001
    3,103
    Richmond, VA
    That is exactly why /forums/images/graemlins/thumb.gif
    John
