Napa#447 ujoint doesn't fit...shouldn't it?
Discussion in 'The Garage' started by angrysnowplow, Aug 19, 2003.
  1. angrysnowplow
    angrysnowplow 1/2 ton status
    Jan 8, 2002
    502
    MA
    Napa#447 ujoint doesn\'t fit...shouldn\'t it?
    OK, my Blazer is a 90, the 14 bolt is out of an 86 CUCV.
    I picked up Napa p/n 447, and attempted to install it, but it doesn't fit. Comparing it to the stock ujoint from the 10 bolt, all the dimensions are the same, except for the groove where the snap/clip rings go. On the 447 joint, they are too far outboard to get the clips into them.
    I thought it was a 348 for a 12 to 14 bolt and 447 for a 10 to 14 bolt. But my truck is never that simple. /forums/images/graemlins/thinking.gif /forums/images/graemlins/1zhelp.gif
  2. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    Re: Napa#447 ujoint doesn\'t fit...shouldn\'t it?
    Mine was the same way.. The part number is 448 for the right one.. I went threw that.. I guess it is foir a 3/4 ton driveline.. /forums/images/graemlins/thinking.gif
  3. angrysnowplow
    Jan 8, 2002
    502
    MA
    Dayum! 4 minutes later, thanks. /forums/images/graemlins/thumb.gif
  4. gokartergo
    Dec 2, 2000
    5,855
    Hollister, CA
    LOL I know how you feel.. I thought I had every thing I needed for my swap.. Then I go to put the U-joint in and it wouldn't fit.. I had to take the driveline down to the napa dealer and do the measurements.. Then found out somebody had put in a 3/4 ton driveline.. Good luck..
  5. angrysnowplow
    Jan 8, 2002
    502
    MA
    At least I have another excuse to not mow the lawn. /forums/images/graemlins/grin.gif
  6. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I drive a '90 Jimmy and when I did my swap neither I don't think either of those worked. Went to the drivetrain shop and found out I had a 3r yoke on my driveshaft. We searched the Spicer catalog and couldn't find a conversion joint from a 1350 to 3r. Checked at the local spring shop and they informed me of the same thing. I ended up having to get some joints made by B'ham Powertrain. Sucks, because I could have had a shaft made for less than I have spent on these joints.
    Hope the same doesn't happen to you, but at least you won't think you're crazy (like I did) if the joints don't work.
    Lance
  7. angrysnowplow
    Jan 8, 2002
    502
    MA
    Ruh-Roh. I have a feeling this is what's wrong. Would it be a bad idea to modify the yoke? (Just a little bit, it's so close) /forums/images/graemlins/thinking.gif
  8. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Yokes are cheap. Have your driveline man slap a 1350 on your shaft and you can use cheap, redily available u joints.
  9. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    /forums/images/graemlins/shocked.gif /forums/images/graemlins/shocked.gif NOOOO, say it isn't so. /forums/images/graemlins/frown.gif /forums/images/graemlins/mad.gif
    Who has done the 10-to-14 bolt swap and had Napa #447 work for them? Please, someone, give me some good news. /forums/images/graemlins/ears.gif
  10. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    447 dident work for me either (10-14) but I HAD to drive my truck that day So i pulled the caps off the 10bolt u-joint and stuck them on the 447 and it works fine but Im not sure I would recomend doing this
  11. angrysnowplow
    Jan 8, 2002
    502
    MA
    I must have the same yoke that Lance was talking about. I asked FatBoyBlazer (his truck is a year newer so I figured it'd be the same for him)what he did but he said he used the 447 joint; didn't mention any problems.
    Napa guys looked this up in their magic book and said that it called for the 447 too...makes my head hurt. All I know is that 20 minutes with a file works wonders. /forums/images/graemlins/ignore.gif
