Napa Brake lines again
Discussion in 'The Garage' started by KWA, Mar 10, 2006.
  1. KWA
    KWA Registered Member
    Jan 11, 2005
    17
    Hawaii
    I did search but still need some clarification.
    I am going to put a 4 inch Tuff Country lift on my 1991 Suburban (10 bolt front) and want to put on the Napa brake lines but wanted to make sure I get the right ones. Seems like there are two sets of part numbers that people are using.
    2wd Chevy/GMC 89-2000
    38873 or 38872 (front) 25 7/8 inch
    4138068 (rear)
    1990's 3500HD
    38622(L) 25 3/4 inch
    38623(R)
    38068 (rear)
  2. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I believe most use the 38873 / 4138068 lines. I used them on my 88 10-bolt and as far as I know its the same setup on the 91 burb.
  3. ARAMP1
    ARAMP1 Aviator Extraordinaire
    Sep 1, 2005
    3,983
    55
    Memphis, TN
    The 38872 and the 38873 are actually a little bit different. I got one of each and eventually decided to take the 38873 back and just use the 38872 on each side. $12.99 from NAPA too.
  4. midnitewarya
    midnitewarya Sounds like a problem for future me. Premium Member
    Dec 1, 2002
    1,726
    20
    SoCal
    I used the 38068 on my rear when I did the 14bff swap. I got a 6" lift, and it's a perfect fit.
  5. KWA
    Jan 11, 2005
    17
    Hawaii
    Okay did a little more research.
    - 38873 and 38872 have a square banjo(?)
    - 38622(L) and 38623(R) have a roundish banjo(?)
    It sounds like either will fit though. I'll see what they have in stock.
  6. black'burb
    black'burb 1/2 ton status
    Mar 11, 2005
    182
    Northeast WA
    I just bought those for my 91 Sub 2500. I used 38622 and 38623, they fit perfectly...
  7. KWA
    Jan 11, 2005
    17
    Hawaii
    Thanks everyone,:D
    Picked up 38622(L) and 38623(R) they look like they will fit, but won't be able to get to it for a while.
  8. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,721
    11
    Washington State
    where are these made? what is the quality?
  9. KWA
    Jan 11, 2005
    17
    Hawaii
    This is an old thread :D, but funny thing is I tried to put the Napa brake lines on just last week. Talk about procrastination :haha:. The bottoms of the brake line that goes on the caliper needs to be ground a little. It fit on my caliper after it was shaved a little, however I didn't like how the metal part of the caliper only faced up and not away from the tire so I had some custom ones made locally. I may have gottine the wrong ones :confused:.
