NAPA brake lines who's gottem?
Discussion in 'The Garage' started by BIG B., Jul 31, 2003.
  1. BIG B.
    BIG B. Registered Member
    Mar 10, 2003
    48
    SAN DIEGO
    NAPA brake lines who\'s gottem?
    After doing a lot of searching on extended brake lines. I decided that when the time comes, I am going to try the NAPA rubber brake lines. I read of some people using these as an alternative to pricey SS lines. Just wondering if anyone has used these and how they worked out.
    The part numbers that I found are:
    Front lines PN:38872
    Rear lines PN:4138068
  2. TrcksR4ME
    TrcksR4ME 1/2 ton status
    Feb 11, 2002
    2,482
    Seattle, WA 98103
    Re: NAPA brake lines who\'s gottem?
    I was thinking of going that route, but decided to buy the pro-comp set since it also has the rear line. I found JC Whitney to be the best buy at $87.95 for the set, and you can get another 10% using their catalog discount for orders over $80 /forums/images/graemlins/laugh.gif So it comes to like $79 and shipping.
    Not sure what the Napa's cost, but I'm guessing they'd be at least half the cost as the pro-comps, no rear line, and still not S.S. /forums/images/graemlins/thumb.gif
  3. JeremyK5
    JeremyK5 1/2 ton status Premium Member
    Aug 12, 2001
    549
    Indiana
    I'm using both of those lines and I have a 4" lift. I have them attached to the hard lines in the factory spots, an they've worked great for me. Plenty of slack. I paid $17 each for the front ones, and a similar price for the rear one.
  4. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    I have Napa's on mine, fit correctly, have slack, no problem's. I think I paid around $60.00? for the two.
  5. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    Hey,
    I have the lines with a 6inch lift and they will work all the way flexed out (my shocks limit my flex somewhat). Good quality and cheap to replace. Nothing like "upgrading" the rig with parts you can still get off the shelf. I recommend them.
    Blake
  6. Lance
    Lance 1/2 ton status
    Mar 4, 2002
    606
    Birmingham, Alabama
    I've got 'em. As others have said, they fit and work great. They have plenty of slack and were and inexpensive alternative to the stainless ones. However, down the road I think I'll end up upgrading to the stainless ones for the extended durability and longevity the stainless ones provide, but no time soon.
    Lance
    ** I don't remember which was for which but I saved the boxes my lines came in and they list part numbers 4138068 and 4136761.
  7. NITRO
    NITRO 1/2 ton status
    Jan 9, 2002
    1,057
    Frankfort In
    i payed like $12 a piece for my lines. they worked perfect for the 4" lift. plenty of slack in them. since they r only on my offroad rig, i think ill prolly just stick with them and use the $80 for the SS lines elsewhere.
    NITRO
  8. NITRO
    Jan 9, 2002
    1,057
    Frankfort In
    NITRO
  9. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    I really like skyjacer lines there pretty cheap to I think it was $35 for my 6-8in lift front lines
  10. swampblazer
    swampblazer Registered Member
    Mar 31, 2003
    49
    mass, u.s.
    ive got the pro comp kit on my rig. its a personal fav. plenty of slack and no rubbing!
  11. 87sm465np208
    87sm465np208 1/2 ton status
    Aug 28, 2002
    1,114
    illinois
    go with the napa, i did, the work great, fittings fit right on the caliper, i had a chafeing problem tho, so i fixed that with a sectino of old fuel hose, cut a slit down the middle and then fit it over the line, they work great as far as flex and stuff tho, plenty of slak, and you can get them at your local napa store, btw my rear napa line i think was alittle short, i used a extension bracket on the rear one, good luck, happy wrenching /forums/images/graemlins/thumb.gif.
    /forums/images/graemlins/usaflag.gif /forums/images/graemlins/truck.gif
  12. gravdigr
    gravdigr 1/2 ton status
    Apr 15, 2003
    1,129
    Tyrone, PA
    Thanks for asking this question, and thanks to those that answered. I have been considering this as well since my 5" lift has my stock lines stretched to the max (the rig is still being built). I didn't know napa had extended lines and on my budget $80+ is hard to cough up for pretty stainless lines. I'm sure rubber lines will suit my needs just fine since I am not making a show truck and at under $20 a line they will be painless to replace.
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  13. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I agree... my budget project wouldnt ever have brakes if I had to save up and spend 80.00 on SS brake lines.... just not possible right now.
    So the Napa lines seem like a great alternative.
    my question to everyone is what were your part numbers?
    there were these: 4138068 and 4136761
    and these: Front lines PN:38872 (this number seems too short) Rear lines PN:4138068 (same number as above)
    Anyone else have numbers?
  14. MTBLAZER89
    MTBLAZER89 3/4 ton status Premium Member GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    well I went to the napa website the 38872 Looks like this
    The 4136761 ones look like this
    I believe the difference is the Dana 44 or 10 bolt calipers. I used the 38872 on my 10 bolt IIRC. The 38872 is a few bucks cheaper too. It says the 38872 is 25 7/8" long.
    The 4138068 is the rear hose. Hope this clears it up.
  15. B_to_C
    B_to_C 1/2 ton status Author
    Jan 15, 2003
    1,861
    In Government Housing
    Mine work great with 4" of lift, couldn't be happer. And yes even though the part # is short, it is correct :thumb:
  16. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    I am still trying to find out what ones will fit my D-60
    38872 :dunno:
    38873 :dunno:
  17. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Either one should fit the 60. They look to be the same on Napa's site 38872 and 38873. It lists a left and a right for each part #. I don't have my boxes anymore, but I'll check my receipt's folder tonight.
  18. stallion85
    stallion85 1/2 ton status
    Jul 11, 2003
    3,659
    Cedar City, UT
    I've got em'. Seem to be the perfect fit for my truck. I only have a 2 1/2" lift though. If you have a lot of flex and a 4" or higher I would not recommend them. Mine still get pretty close, but I have no sway bar and my front flexes pretty good. Just my 2 cents
  19. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    OK I was bored so I dug through my receipt's. I used the 38873 for both sides. Total came to $32 and some change. Both fit with no mods. This is on a 10B so should work on a 60:waytogo:
  20. cbbr
    Jul 17, 2004
    14,681
    High velocity, Low altitude
    I used the NAPA extensions. Fit b/t the bracket and the OEM brake line. Cheap and work great.
