napa brakeline part numbers
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by EODBRIAN, Jun 15, 2000.
  1. EODBRIAN
    EODBRIAN Registered Member
    Feb 19, 2000
    82
    Indiana
    someone posted it a while back. went back and searched but couldn't find it. what are the part numbers for extended lines for front brakes from napa?? thanx.
    EODBRIAN
  2. Grim-Reaper
    7,385
    Atlanta
    The part number changes about every 24-36 months. Take a old line to NAPA and they have a big book with pictures and specs and they can figure it out. Unless your truck is the same year as the one they listed the PT# for there is no garantee it will be the correct one. It seems that the big pt# that gets passed around is 82-85. I can tell you this doesn't resemble the one on a 79 and a 75 and the 75 is different than the 79.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  3. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    I used Napa P/N 38872 on my '90, but as Grim mentioned, there are several different styles used over the years.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I tried the 38872, but the hole for the banjo bolt at the caliper was too small. I'm running a Dana 44, 8-lug front end, so perhaps they used a different size on these.
    http://ThunderTruck.ColoradoK5.com
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Someone was saying Napa is Dana, they don't change there part # that offten do they.
    Is your Napa carrying oil seals manufactured by Victor ?
    Is your Napa carrying u-joints that are manufactured by Spicer ?
    Thanks alot
  6. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Before you buy the NAPA lines, make your numbers. I think you can get the Explorer Pro Comp stainless steel lines for about the same money.
    <font color=blue>//////
    http://blazer79.coloradok5.com
    </font color=blue>[​IMG]
  7. Grim-Reaper
    7,385
    Atlanta
    Well I don't know about them "being Dana" but they do sell Dana Spicer seals and parts. Thats the only place I will buy axle and case seals because they still have the good USA made seals. They to are getting cheap and even some of the stuff packaged in Dana packing is the cheap China / Japan junk. Try to avoid those when buying seals. Be sure to check the parts for the USA label.
    Grim-Reaper
