napa brakelines for dana 44 12 bolt
Discussion in 'The Garage' started by the excuse, Jan 31, 2004.
  1. the excuse
    the excuse 1/2 ton status
    Dec 9, 2003
    209
    san diego
    what part numbers do i get for the brake lines at napa that are longer i have a 4 inch lift. so far in searching ive found 2 numbers for the front lines Bh38621 for one side and Bh38620 for the other. i have also found 38872 for both fronts. i also read that the dana 44 has a different fitting than the 10 bolt and dana 60. which numbers should i get. i found 4138068 for the back.
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I used the 38872's for my D44 and just drilled out the caliper fitting hole on the hose and it works perfectly /forums/images/graemlins/thumb.gif
  3. 83_chevy_blazer
    83_chevy_blazer Registered Member
    Nov 18, 2003
    20
    i went to napa and a bunch of other stores with no luck. the only thing that came close was a passenger brake line for a 83 deisel 2 wheel truck. the only problem was the driveside was completely different.
  4. 83_chevy_blazer
    Nov 18, 2003
    20
