NAPA doesnt carry a pitman arm for my K5?
Discussion in 'The Garage' started by dammit32, Mar 29, 2005.
  1. dammit32
    dammit32 1/2 ton status
    Jul 20, 2002
    365
    Maine
    Is my K5 getting to old to get parts for it?
  2. 1985K20
    1985K20 1/2 ton status
    Jan 11, 2005
    191
    Quebec,Canada
    Im not sure, but the problem could be the guy behind the counter...sometimes they just dont feel like making the effort to open the right book. :(
  3. Silver84k5
    Silver84k5 1/2 ton status
    Feb 7, 2002
    3,769
    Hillsboro Oregon
    go to the junkyard, its cheap... Plus. a pitman arm isnt really a part that gets worn out, so i wouldnt be surprised if you couldnt get one from a parts store.
  4. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    What pitman arm do you need? A drop pitman arm can usually be special ordered by parts stores if you can get the guy to actually look up the part you need. It will probably be in a book from a lift company not in there computer of parts depending on the store.
    I got my Ford drop pitman arm for crossover steering from Checker.
    Harley
  5. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Some pitman arms actually have a ball joint built into them. When the ball joint wears out, you have to replace the entire arm. (My '91 S-10 is like that). But on a K5 pitman arm there isn't anything to wear out, so the demand for them is pretty near zero. If yours is bent or something then a junkyard is probably your best bet (or someone parting out a rig on CK5). :cool1:
  6. dammit32
    Jul 20, 2002
    365
    Maine
    My pitman arm was loose on the steering box and has seen some bad wear from being that way and doesnt seem to stay tight....seems to like to pivot downwards....I'd feel better with it replaced and a nice nylon locknut on the bolt
  7. sweetk30
    Nov 1, 2004
    25,526
    526
    horseheads , ny 14845
    actualy the factory nut is a crimp style nut. and if the arm is that sloppy the shaft might be bad also.
  8. santana
    santana 1/2 ton status
    Jan 11, 2003
    1,483
    Mesa Arizona
    Yeah, what he said but if you need one I have one here. PM me if you need it.. ;)
