NAPA electric fuel pump question
Discussion in 'The Garage' started by opfor2, Jun 12, 2006.
  1. opfor2
    opfor2 1/2 ton status
    Oct 28, 2002
    375
    Ventura County, CA
    Hi all,
    Just wondering if anyone has ever used NAPA's hi flow fuel pump? I want to change out my fuel pump on my 90 Blazer as a PM thing before it goes out on me. I figure with a 125K on it it's about time. I'm wondering if the 26 PSI and 15.95 GPM is a good thing. The add states: (Turbine Upgrade Over the Original Equipment Pump. This Turbine Upgrade Provides Optimized Fuel Flow Less Noise/Vibration a Lower Current Draw Longer Life Expectancy Improved Provability Economy and Performance over the Original Equipment Pump.)
    thanks in advance
    http://www.napaonline.com/MasterPages/NOLMaster.aspx?PageId=470&LineCode=BSH&PartNumber=N69238&Description=Fuel+Pump+(OE+Electric+In-Tank+Type)
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    you know, fuel pumps aren't really a maintenence item unless they are causing an issue...
  3. opfor2
    Oct 28, 2002
    375
    Ventura County, CA
    True, an electric fuel pump may not be a PM item but after reading all the posts I think that it would be cheap insurance to change the original OEM pump with 124K on it before it goes out and leaves me stranded out somewhere inhospitable. I'm not complaining about spending fifty dollars for a replacement pump.
  4. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Are you running additional fuel pressure? If you plan on future mods, upping the fuel pressure is a must...probably good idea with a stock motor too (a little more). I would think this pump would handle the increase in pressure for the lonf term better, but its hard to say. My stock replacement pumps handle 20 psi all day long...
