NAPA extended rear brake line part number?
Discussion in 'The Garage' started by OneInTheSun, Oct 3, 2002.
  1. OneInTheSun
    OneInTheSun 1/2 ton status
    160
    Pittsburgh, PA
    I know the fronts are 38872. Has anyone found out if NAPA has an extended rear line to go along with the 38872? Part #?
  2. ColAdo82K5
    ColAdo82K5 1/2 ton status
    Feb 18, 2000
    789
    MO
    i wish someone would..it would save me some $$ !
    Blake
  3. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    I just made a new bracket few inches longer and lowered the factory mount down from the frame. Works great and doesn't get in the way since its mounted dead center of frame rails.
  4. ChevyHuny
    ChevyHuny 1/2 ton status
    Aug 17, 2001
    2,279
    Washington State
    When I picked up my front brake lines from napa he told me he could find what would fit the rears if he had a part number for them say from a 4x4 shop. He hunted down the fronts for me (the 33372s) and made sure they would work on my truck before I paid for them. I trust what he says. Maybe someone at a Napa near you could do the same? I still have to go in and get the rear line so if I get it done before anyone finds it I will post it.
  5. chulisohombre
    chulisohombre 1/2 ton status
    Apr 11, 2002
    4,139
    14
    Bangor,Pa
    exactly wht mine has.i just bent the brake lines up a couple of inches then bolted a 2 inch lift bracket for the proportion valve to bolt to and left the stock rubber hose in place.
  6. ColAdo82K5
    Feb 18, 2000
    789
    MO
    I made a spacer bracket from the axle as well but i wouldn't mind a little longer line back there.
    Blake
  7. RedBrute
    RedBrute 1/2 ton status
    Sep 22, 2002
    346
    Southern tier New York
    Try part NAPA #4138068, I used this on my K5 when I did the 4 inch lift. If I recall it's 4 inches longer than stock, plenty of slack. Price is right, $13 /forums/images/graemlins/thumb.gif
