napa part #'s for 14bolt rear conversion needed.
Discussion in 'The Garage' started by milspecjimmy, Jan 12, 2003.
  1. milspecjimmy
    milspecjimmy 1/2 ton status
    Aug 28, 2002
    901
    raymond, maine
    napa part #\'s for 14bolt rear conversion needed.
    i am going to make a list of what parts i think i need, and napa is the best place to get them. if any one has done this swap and knows hte part #'s it would help.
    i think i need:
    4 u bolts for the rear axel, 2 new steel brake lines, one extended rear rubber one, 1 dist block for the brake lines, the conversion joint. the front axel is a 44 so it will all cross right over. any thing you can think of that i missed? thanks a lot
  2. K5Dan
    K5Dan 1/2 ton status
    Nov 15, 2002
    583
    Port St. Lucie,Fl
    Re: napa part #\'s for 14bolt rear conversion needed.
    i think the u-joint is 447 that's the one i used.
  3. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    any one have the # for the extended rear line?
  4. fourwheelerjeff
    fourwheelerjeff 1/2 ton status Staff Member Moderator
    Nov 16, 2001
    3,419
    6
    meadow, tx; in the boonies
    Try part NAPA #4138068 /forums/images/graemlins/thumb.gif
  5. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    will my rough country u bolts fit the tube on the 14? or do i need those too?
  6. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    The Ujoint is #447. If you have a 10 bolt and are swapping to a 14ff the flex line will bolt right up. If going from a 10 bolt front to a D44 the lines are different. If going from a D44 to a D60 the lines are different. You can use the same lines for a 10 bolt and D60 calipers though. The ubolts are a different size from a 10 bolt to a 14ff.
  7. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    my 10 bolt front calipers will bolt right on the 44 front right? this front axel looks exactly like my 10 bolt only 8 lug
  8. wayne
    Feb 1, 2001
    6,178
    Carlisle, Pa
    As far as I know they will.
  9. milspecjimmy
    Aug 28, 2002
    901
    raymond, maine
    ok so the front end doesnt look to be a problem, the rear needs to have a new ebrake setup, new u bolts and a conversion joint.every thing else is just so. or am i wrong?
  10. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    yes they will bolt up, just did it /forums/images/graemlins/grin.gif
  11. supersize75
    Sep 27, 2002
    2,638
    .u-joint is 23.00 get te u-bolts from the junk yard, and plates too. or get one u-bolt take measurements and have new ones made.
