Napa parts numbers
Discussion in 'The Garage' started by xtrmjoe, Oct 6, 2004.
  1. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    I searched but could not find what I needed. I went to napa in napa ca today and the guy could not find a part number for the rear axle bearings on a 86 blazer with gm 10 bolt 8.5" 28 spline axle. He could not find the seals, for the front or the rear.
    any help greatly apprecited.
  2. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
  3. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    link not working
  4. 55Willy
    55Willy 3/4 ton status
    Jun 2, 2001
    9,946
    Keizer, Or
  5. xtrmjoe
    Aug 3, 2004
    330
    Boonville, CA
    He found some parts but not the right ones. I took them in with me and what he pulled was NOT what I needed.
  6. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/screwy.gif
    Just enter then info for your Blazer where it says 'change vehicle' and go to 'drivetrain' then 'rear axle parts'.
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i have napa catalogs, you need any part numbers then get a hold of me
  8. diesel4me
    Jul 24, 2003
    17,540
    927
    Massachussetts
    Someone may have swapped a different axle in it if the parts listed wont fit--if all else fails the part numbers are stamped on the old bearings and seals(of course they usually get mangled when you remove them)but you should be able to match a new bearing up to the old one,and use the seal that goes with that bearing,--as far as I can remember there is only 2 different rear wheel bearing #'s on a 1/2 ton,shouldnt be too hard to figure it out--I think one has "log"style rollers,the other is a sealed ball bearing.
