Napa u-joint #
Discussion in 'The Garage' started by BLZN4FN, Mar 16, 2007.
  1. BLZN4FN
    BLZN4FN 1/2 ton status
    Dec 19, 2000
    1,720
    Englewood Colorado
    Yes I searched and I cant find the #:eek1:
    What is the part number for the rear u-joint to go from 10 bolt to 14 bolt?
    I need a spare and for the life of me find the part #.
  2. bluehen
    bluehen 1/2 ton status
    Nov 11, 2004
    215
    DE
  3. kwissman
    kwissman 1/2 ton status
    Jan 14, 2006
    118
    Austin, TX
    It can be either a 447 or 448 depending on if you have a 1310 or S3 joint on the 10B. Measure the cross and cap and compare to the joint at the store.
  4. big dan
    big dan 1/2 ton status Premium Member
    Aug 1, 2005
    2,656
    29
    Arkansas
    most 10 bolts use an s44 joint which requires the #447.
    If you have a 12 bolt or someone swapped in a yoke and driveshaft for the 1310 you will need a #348.
  5. K-5 Bomber
    K-5 Bomber 1/2 ton status
    Aug 20, 2006
    108
    Northeast California
    Are you using your stock drive shaft? I took the heavier shaft from my donor truck and had to measure the caps to get the correct one.
