Narrow Rearends?
Discussion in 'The Garage' started by K5 Silverado, May 1, 2007.
  1. K5 Silverado
    K5 Silverado Registered Member
    Apr 19, 2007
    22
    Washington
    I search for this question but, all I came up with is gears. Why is the rearend of my Blazer narrower then the front? if I put 3/4 rear ends in it will it set the same or will it even out?
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The rear is roughly 3" narrower than the front. It has to do with turning radius. The only way you'll get close to the same track width is by installing a 14ff van rear axle. Those are very close to the same width as a front axle.
  3. K5 Silverado
    Apr 19, 2007
    22
    Washington
    I heard of people useing wheel spacers. But I was told that they are prone to break and causing the wheel to come off. anybody used these was towing?
  4. drop the hammer
    drop the hammer 1/2 ton status
    Feb 26, 2006
    160
    Massachusets
    heard it was due to turning radius, and so that your rear tires dont exactly follow your front tires tread, in theory giving you better traction, but who knows GM has had some wacky ideas. Heard a 1 ton trucks 14 bolt ff will work but no promises
  5. tRustyK5
    Jul 23, 2000
    36,178
    1,387
    E-town baby!
    1/2 ton are 67.5" wide front, 65" rear.
    3/4 and one ton are 69.5" wide front, and 67" rear.
    The van 14 bolts are 70" IIRC.
    Rene
  6. mechted
    mechted 1 ton status Premium Member
    Oct 19, 2003
    766
    Granbury, TX
    oh, so it wasnt just my imagination that the wheels looked further out with the 60 in.
    btw, narrower rear has nothing to do with increased traction, with the rear wheels closer together, you change the center of curvature while turning, making it tighter
  7. dyeager535
    26,980
    I know we've gone through this before, but different track for front/rear does increase traction in certain environments. Snow is a big one.
  8. Mudstud
    Mudstud 1/2 ton status
    May 29, 2001
    1,472
    Memphis, TN
    and mud is another.
  9. xtrmjoe
    xtrmjoe 1/2 ton status
    Aug 3, 2004
    330
    Boonville, CA
    This was true with the old style spacers. I have 1.5" spacers and they are machined aluminum and are quite burly. I had the same concerns as you at first but have had no issues with them in over 2 years. I do check the lug nuts often though to make sure they are always tight, paranoina relly I have not had any loosining of the lug nuts.
  10. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    Yea I want to run 2.5 to 3" spacers on my rear and I won't worry about it at all. Just need to find someplace that doesn't want an arm and a leg for em.
  11. obijuan
    obijuan 1/2 ton status GMOTM Winner
    May 18, 2006
    4,009
    San Antonio TX
    offroadoverstock.com isnt too bad on price.
  12. Mudstud
    May 29, 2001
    1,472
    Memphis, TN
    I'd prefer used and around a $75 price tag.
