Narrowest track width possible for D60 frt?
Discussion in 'The Garage' started by Ned Kelly, Apr 9, 2005.
  1. Ned Kelly
    Ned Kelly 1/2 ton status Premium Member
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    What is the narrowest track width I could get on a D60 frt using a 8" wide rim? I figure I could run about 5" BS and still have about 1/2" clearance to the tie rod. Ideally I'm trying to achieve a 63" track (center to center) if I can. I want to run a 36" or 38"/12.50 tire if I can. Maybe a Q78-16 if I have to.
    My other option is to cut down the drivers side axle tube and shaft, but just checking if I can get close to 63" with custom rims (since I need rims anyways) and not shorten the axles.
  2. sapper
    sapper 1/2 ton status GMOTM Winner
    Jul 11, 2001
    3,052
    NoVa
    I have a dodge 60 in my truck and it matchs the 14ff in the back without any spacers, my rims are h1's so they are at 8.25"s wide and with 39.5"TSLs my total width is 82"s, heres a pic.
  3. CyberSniper
    Apr 21, 2003
    2,257
    5
    Chelsea, MI
    17" wheels
  4. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    thats what i was thinking, you gotta get a pretty big wheel so you can tuck the tierod end inside.
  5. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I just looked at my current setup. Looks like a 5"bs rim would be the max. Thanks for the replies.
  6. Emmettology 101
    May 9, 2000
    8,126
    FL
    Even with 17's I think it would be hard to get down to 63" track width when the wms-wms measurement is 69.5"..... I thought I read somewhere that you still have issues with the stock tie rod mount with the 17"wheels..??.. You'd need to cut it down. BUt even cutting down the long side 3" is only going to get you down to 66.5"....
    You putting this under a K5 or something like a Toyota?
    I'll be dealing with this soon. To come close to matching the rear and get my perch width to match my Toy, I could cut the long side down 3".... But I want to run hummer wheels with DRW hubs. So I figure I am goign to have to cut the long side down 5" and the short side 2"........... :crazy:
  7. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I wanted to put in under a Dodge M37. Pin to pin measurement on the front springs is 28 3/4". I was just figuring if I could do it without cutting the axle down. Looks like I would have to cut down the long side by 3 1/2" to fit it.
  8. Emmettology 101
    May 9, 2000
    8,126
    FL
    If you cut down the long side by 3", that will give you a perch with of 29" which will be close enough... Same as the guys with the Toys do...
  9. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    What's a good place to get a shortened frt shaft from? I haven't checked into this yet. A stock strength shaft would be ok for my use.
  10. Emmettology 101
    May 9, 2000
    8,126
    FL
    Do you know if you have the necked down shafts or the good 81(or so) + shafts? If you have the non-necked down shafts, you could get that side cut and resplined at Moser Engineering... I think it's about $50 for one shaft.
  11. Ned Kelly
    Mar 1, 2005
    903
    16
    Winnipeg, MB
    I have the non-necked down shaft. Thanks for the info, good to know the approximate cost I'm looking at.
  12. Emmettology 101
    May 9, 2000
    8,126
    FL
    Just double checked their site and it lists one axle at $55 and a pair(at the same time) for $95... :thumb:
