Nasty smog test results. Could use some help.
Discussion in 'The Garage' started by docgab, Aug 13, 2003.
  1. docgab
    docgab 1/2 ton status Premium Member
    Oct 1, 2002
    1,166
    Medford, OR
    Greetings all, I finally got the ugly beast's smog equipment on and ready to try and smog. Oh man how nasty it was. Here's the results:
    2500 RPM:
    HC PPM Allowed: 0350
    HC PPM Measured: 1857
    CO % Allowed: 3.50
    CO% Measured: 13.67+
    Idle RPM:
    HC PPM allowed: 0300
    HC PPM Measured: 0624
    CO % Allowed: 3.00
    CO% Measured: 9.14
    Nasty stuff eh? This was all after changing spark plug wires, plugs, cap, rotor, oil change etc. Timing was 4 BTDC, idle was 650 or so. Q-jet carb, 350 motor. The tech said the HC is generally carb related. I have a buddy who can loan me a new Edelbrock Performer carb for the test so that should answer that part of the question correct? Any other things I should look at?
    Another thing I was concerned about was at sustained 2500 RPM, my right exhaust pipe (I have true duals) was blowing smoke like crazy, not black, not white, kinda blue or gray if I recall correctly. The left wasn't so bad. All input and suggestions are greatly appreciated! /forums/images/graemlins/thumb.gif
  2. docgab
    Oct 1, 2002
    1,166
    Medford, OR
    ttt- anyone? C'mon, I know ya can't be that tired of all my questions!?!?! /forums/images/graemlins/thinking.gif /forums/images/graemlins/rotfl.gif
  3. Sample
    Sample 1/2 ton status
    Oct 15, 2002
    536
    Apache Junction, AZ
    High HC's caused by bad or no Cat.
    High CO caused by running too rich.
  4. diesel4me
    Jul 24, 2003
    17,553
    939
    Massachussetts
    Whenever its emission test time foe me I always get the engine in good tune,and advance the timing a little beyond normal specs,make sure I have only 1/4 tank or less of gas and add 3 bottles of isopropanol dry gas.I have had big blocks that had over 200,000 and only in fair condition pass with quite a bit lower emissions than the limits, /forums/images/graemlins/deal.gifafter failing just a few minites before without the dry gas.I dont know if the new "sniffers" can tell the difference in fuels(to detect cheaters like me) /forums/images/graemlins/ignore.gifbut it worked for me,and I have seen similar stuff for sale that says gaurenteed to pass emission test or you get it free.Its cheaper than a new engine,one that will probably pollute just as bad as a used one anyway!. /forums/images/graemlins/grin.gif
  5. docgab
    Oct 1, 2002
    1,166
    Medford, OR
    thanks for the replies so far all. Much appreciated!
