Natural resting position of an ORD shackle/flip
Discussion in 'The Garage' started by kyser_soze, Apr 29, 2006.
  1. kyser_soze
    kyser_soze 1/2 ton status
    Sep 4, 2004
    3,180
    KC Missouri
    I just installed a shackle flip kit on my 1997 K3500 and would like to know th natural resting position of the shackle with a non-loaded bed.
    Mine seems to be on an angle and not vertical. Is this correct?
  2. 71 Blazer
    71 Blazer 1/2 ton status
    Jul 16, 2005
    184
    windsor virginia
    On my 71 Blazer the shackle is almost straight up and down. That is with the hard top on(heavy). Did you put the wrong shackle on the wrong side? That is how mine looked when I first did my shackle flip, then I swapped the left and right one to get them straight up and down. Not sure which locating is correct, but I like having the shackle straight up and down.
  3. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    looks good to me. not sure about the 90's trucks, but my 89 came out pretty much straight up and down. a little rake like you have is usually preffered tho. should give u a softer ride and increased suspension travel compared to a straight shackle
  4. yellowK20
    yellowK20 Well Lubricated Premium Member GMOTM Winner
    Dec 26, 2002
    7,602
    554
    Wasilla AK,
    that's good there if anything you'd want a little bit more angle
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    no worries the angle looks fine. then again if your going for more flex a longer shackle and moving the mount forward on the frame woul be awsome;)
  6. oneofthefewbmx
    oneofthefewbmx 1/2 ton status
    Oct 6, 2004
    579
    Copperas Cove, TX
    the shackles should be pointed slightly rearward (the way they are now). the angle looks good....i second the idea of longer shackles and possibly moving the reverse shackle foreward if you want more articulation....other than that it looks good.
