natural safety switch
Discussion in 'The Garage' started by wildmandave, Feb 26, 2007.
  1. wildmandave
    wildmandave 1/2 ton status
    Jul 15, 2006
    127
    salina kansas
    wheres the location of the neutral safety switch on a 1995 suburan? my starter is good, but won't turn over. thanks
  2. bigblazer87
    bigblazer87 1/2 ton status
    Dec 20, 2006
    333
    Elk Grove, CA
    Do you mean neutral safety switch?
  3. Bow-Tie-Boy
    Bow-Tie-Boy Registered Member
    Feb 14, 2005
    71
    Ft. Hood, Texas
    Underneath the steering column. If you move the shifter around while turning the key, it should try to start. If that doesn't work, check the fusible link.
  4. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    and if that doesn't work, make sure you have the ignition wires hooked up on the correct terminals of the starter solenoid,,,i just helped get a persons car "running" after somebody replaced the starter and put the wires on the wrong terminals of the solenoid.
  5. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    95 first year with new dash style and cluster. i bet its the one on the side of the tranny on the shifter shaft. and if so also plan on new plug ends if switch replacement is in the plans. thay glue them in from the factory and dont like to remove to well.
  6. wildmandave
    Jul 15, 2006
    127
    salina kansas
    i looked under the dash and can't find any thing. there is abunch of wires on the side of the tranny. the starter has 2 wires one big and little one.
  7. wildmandave
    Jul 15, 2006
    127
    salina kansas
    does anyone have a pic of the wiring for the safety switch?:confused:
