naval jelly
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rusty79, Nov 29, 2001.
  1. rusty79
    rusty79 1/2 ton status
    Jul 22, 2001
    139
    Hampton Va
    just wondering if anybody has ever used this stuff seems to be working pretty good for me but if anybody had tips on using it?
  2. ftn96
    ftn96 1/2 ton status
    Sep 26, 2000
    3,238
    Nashville Tn
    Paint it on thick and leave it on there on contrary to what the directions say about cleaning it off. After it dries, you can prime and paint, or just paint. If its on a surface that needs to look nice, get some light sandpaper, say 240 or 320...Smooth it out best you can, then get some sandable primer and go back over that after it dries to get any remaining blemishes out, then your ready to paint.
    No matter where you apply it, you still need to coat it with some paint. The black appearance that it leaves is still porous like primer and needs to be sealed up.
    Surgeon General's Warning:
    Viagra and steroids may be harmful to your spouse![​IMG]
    <a target="_blank" href=http://www.nashvillek5.freeservers.com>www.nashvillek5.freeservers.com</a>
  3. rusty79
    Jul 22, 2001
    139
    Hampton Va
    so just leave it on there and paint over and itll hold up im doing this in my engine compartment btw
  4. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    no no no no he's talking about rust converter, naval jelly must be washed off DO NOT PAINT OVER IT. naval jelly is often pink and is used to remove surface rust, it's not real good at removing the heavy stuff. it should be applied and let it sit for awhile and then remove with a damp rag. what he's talking about is rust converter this is brushed on and it turns black then it can be painted over but it should be sanded good first. what i have done is sanded the rusty area first then apply naval jelly then clean it real good then aplly some converter and then sand it down and the paint. I did this to my floors two years ago and have not had one spot of rust come back.
  5. ftn96
    Sep 26, 2000
    3,238
    Nashville Tn
    I've used the rust convertor and the naval jeely the same way and haven't had any problems with it.
    But dont listen to me just do what the bottle says.
  6. beater74
    May 29, 2001
    1,749
    atlanta
    yeh i though that the naval jelly was kinda harsh and i would hurt the paint in the future but then again i don't know everything.
  7. rusty79
    Jul 22, 2001
    139
    Hampton Va
    i washed it off first it dried in big clumps so didnt want to pait over it at least my engine compart ment is rust free now...just gotta worry about the rest of the truck next
  8. The rust converter that I know of is called Ospho. Don't ask me what that stands for, though. Ospho is really good stuff. Just let it set for a while, like an hour, and then you can paint right over it.
    American by birth, Marine by the grace of God
  9. TXsizeK5
    TXsizeK5 1/2 ton status
    Aug 26, 2001
    2,518
    College Station, TX
    use a tooth brush with naval jelly so you dont get cancer?
    6in 87' K5 w/ 35" BFG muds.
    305/Sm465/ NP208
    Kn, 4.56's.
    In desperate need of a rebuild.
    Next- Eaton mech locker... Flows.
