NBS and 91 same VSS?
Discussion in 'The Garage' started by CHEVY 4WD, Jan 9, 2006.
  1. CHEVY 4WD
    CHEVY 4WD 1/2 ton status
    May 14, 2002
    1,773
    Florida
    OK im REALLY gonna start collecting parts now to do a SAS in my 99 Silverado. Im gonna do a 10 Bolt, and want to swap in a t-case my question is if I get one from a 90-91 Blazer/Surburban with VSS will my 99 speedo still work?
  2. mouse
    mouse 1/2 ton status
    Nov 10, 2003
    1,448
    Great Falls Mt
    Pretty sure those years of burbs/blazers have a cable driven vss - my '89 does. You would just have to buy a sensor for your t-case. I guess you plan on changing the transfer case? You could run your t-case with a driverside drop front axle from a ford...
  3. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    the '91 definintely has an electronic speedo, if i'm not mistaken, the 89 should too.
    any special reason for the 10 bolt as opposed to a Ford Dana 44? would make things much simpler if you went with the Ford 44.
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    I think the VSS came out in 91 for the K-5s and burbs. Only the 88-up NBS style had the VSS. I would get a Ford axle, whether 60 or 44, that way you won't have to go thru that BS. Better driveline angles too.
  5. CHEVY 4WD
    May 14, 2002
    1,773
    Florida
    so its all gonna work RIGHT? btw I DONT wanna run ford parts plus I would have to change out the t-case anyways because I have autotrac and I would only have 4Hi and 4Lo if I left what I have plus i think it would but it up anyways
  6. b454rat
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    An axle out of a Ford doesn't mean it's built by them. iI hate Fords, but don't think I didn't buy a whole truck to get the front end out of it. I would get one out of a 91. Pretty sure they had the VSS that you need. If you can't find one, I don't see why you couldn't swap end housing and tone rings to get VSS. I'm putting a Ford HP60 in my 97 Chevy, doesn' bother me that it's out of a Ford, I don't want to change my case for one, and two, its push button, and I think that would be a wiring disaster. So I just won't change it.
  7. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    89 had a cable, 90 and 91 K5's have vss. I have 2 90's and both are vss. I would also agree with everybody else and get a D44 from a Ford.
  8. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    why wouldnt it work right? the only thing different between an autotrac transfer case is the fact that it doesnt have a shifter. it functions just the same, and you would have the option of 2wd .
  9. gmcman7202
    gmcman7202 1/2 ton status
    Sep 19, 2005
    181
    The land of FIBS
    some autotrac t cases have auto 4 wheel button option, along with 2 hi, 4 hi, 4 low. they have wheel sensors on the front 2 tires, when they are not spinning the same as the rear, it engages. we have this option on my 3 chevys, and my gmc pickup. we do not use the option do to typical harsh engagement that happens. i however do like the ability to just push the button and be in 4 hi rather quick. has been a life saver when i have been run off the road many times in the snow.....
