Neapco conversion joint???
Discussion in 'The Garage' started by MTBLAZER89, Jun 21, 2004.
  1. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Ok awhile back I asked about this or found it in a post. Anyway it said to get the 3-3140 conversion joint from Neapco. I went to install it today and the caps that press into the driveshaft are way to small. I have used the #447 before and it works...does anybody know the correct Neapco #? Napa has 2 #447's in stock but the Neapco from AZ is almost $10 cheaper /forums/images/graemlins/eek.gif
    edit: this a stock 10b shaft to a 14BFF
  2. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    Neapco # 2-1153 Good luck Brian. /forums/images/graemlins/thumb.gif
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I'll 2nd that. 447 = 2-1153 in Neapco. (Saginaw S44 internal locking clips to Spicer 1350) '80s trucks will typically use this.
    348 = 3-3140 = Spicer 1310 (external clips to Spicer 1350) Typically the '70s trucks will use this.
    Easiest way to identify is to look at the lock rings. If your stock u joint has internal locking clips it is Saginaw, if it has external clips it is Spicer.
  4. MTBLAZER89
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    Thanks guys /forums/images/graemlins/thumb.gif
  5. Blue85
    Blue85 Troll Premium Member
    Jul 26, 2000
    9,086
    487
    Grand Rapids area
    I have a used NAPA 447 for sale. I don't need it since I did a fixed-yoke conversion.
