need 10bolt torque specs...
Discussion in 'The Garage' started by MEPR, Apr 10, 2005.
  1. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    Alrighty i need to get the torque specs for a 10bolt front and rear. Im thinking of dumping some 4.10s in it so it will tow the LUV better. So what are the torques ill need to know? (bering caps pinion ect.) Thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Side bearing caps 55-60 ft. lbs.
    Ring gear to carrier 50 ft. lbs.
    Adjusting nut lock bolts 15-20 ft. lbs.
    Cover bolts 20-23 ft. lbs.
    Cross shaft lock bolt 20-25 ft. lbs.
    Ring gear backlash .005" - .008"
    Pinion bearing preload new 20-25 in. lbs. / used 5-15 in. lbs.
    Side bearing preload slip + .008"
    This info came from Drivetrain Warehouse
    These spec are for GM 8.5" 10 bolt and also 8.875" 12 bolt
  3. MEPR
    MEPR 1/2 ton status
    Oct 21, 2002
    1,546
    McChord AFB
    sweet thanks a bunch. Also do you think the Yukon gear kits come whith torque specs as well. I just noticed the master kits come whith an 18page book :)
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    I'm pretty sure they don't give specs in that booklet. That booklet is more of a how to install your gears and read the gear pattern type thing. It also warns you of different types of things to avoid doing.
