need 1985 column electrical diagram - already searched
Discussion in 'The Garage' started by RootBreaker, Jul 6, 2005.
  1. RootBreaker
    Nov 29, 2001
    5,117
    173
    Williamstown, NJ USA
    Ok so I used the search button... but didnt find what I was looking for...
    for some reason my high beam switch is mounted where the clutch smacks it if you push all the way down... since I have a mechanical clutch no biggie as the clutch catches almost all the way up. Now when I drove my parts truck (85 jimmy) into my driveway I noticed the clutch catches say 2-3" off the floor... so this will not be good as it will hit my high beam switch.... ok so move it over and will have no problems.
    While taking the clutch pedal assembly and hydro clutch stuff out... I realized that this 1985 steering column, meant for a manual, with wipers and high beams on the column would look awefully dayum nice in my truck...
    my truck was a 2wd cab that I converted to 4wd (cut hump out and bolted mine in as 2wd humps are not boltins and 4wd are) and also was an automatic to which I converted to manual. Popped the pin out of the column for the shifter.
    so with the column out and pouring rain I decided to look at the column. high beams actually may just unplug from the floor and plug straight into the column as the plug looks the same. However the wipers will be different.
    So with all that winded explenation.... anyone have a diagram of the steering column on a 1985 or a link to the color codes of each the wipers for a 78 & 85 (may be the same as I havent looked into that yet)
    plus this conversion will make a nice addition as high beams on the column are easier to get to and wipers on the dash flat out sucks when trying to reach for them, turn the wheel and shift at the same time!!!!!!! :haha:
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Pm me your email address and I'll email you what I have.
  3. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    When are you going to update the links in this post? I was going to point him in this direction but the links were dead.
  4. Muddytazz
    Jun 30, 2002
    20,073
    Salem, Or.
    Whats wrong with that link, it works.
  5. RootBreaker
    Nov 29, 2001
    5,117
    173
    I think he was pointing to the fact that the links on that link dont work... :doah:
  6. dremu
    Feb 27, 2000
    15,954
    445
    East of San Francisco
    Uhh ...
    http://brochures.slosh.com/wiring/
    is workie, really, and is what I woulda told you anyway :D
    -- A
  7. RootBreaker
    Nov 29, 2001
    5,117
    173
    I just realized that I dont have adobe installed.. as I just re-installed my os.. hence why it isnt working...
    :doah:
  8. mudslinger99
    mudslinger99 1/2 ton status
    Oct 8, 2004
    512
    East Coast
    When I click on that link I get this http://brochures.slosh.com/wiring/
    Then when I click on the links on that page I get this res://C:\WINDOWS\SYSTEM\SHDOCLC.DLL/http_404.htm#http://brochures.slosh.com/wiring/84 chassis 1.pdf ..
    The 1st link brings up the page fine but when I try to click on the links on that page it says ''The Page Can Not Be Found'' ?
    Just thought I would let you know..
  9. RootBreaker
    Nov 29, 2001
    5,117
    173
    ok so it aint me :crazy:
  10. RootBreaker
    Nov 29, 2001
    5,117
    173
    thanks got your email....
    can you hook me up with the electrical for a 78 chevy?
    I got my newer style column in... thank god I cut the plugs under the dash....
    cut off mine for high beams and attached this one... high beams work fine... colors matched...
    wipers are a different story.. I dont know what color is for what on the 78. Thanks...
    Jeff
