Need 4:10's for a 12 bolt
Discussion in 'Parts & Trucks Wanted' started by The85k5, Mar 5, 2002.
  1. The85k5
    The85k5 1/2 ton status
    Feb 22, 2001
    259
    Sunnyvale,Ca
    Need 4:10\'s for a 12 bolt
    anybody have a set? new used....possibly in the bay area?
    Robb
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    Re: Need 4:10\'s for a 12 bolt
    I believe 4.10 werent in 12 bolt.....
    but 4.11 ratio was available from factory in at least 67-72, But are VERY rare to find an example of, have only found one in a '68 suburban in NH just recently
    Tthis 4.11 ratio was incuded when RPO M20 O/D transmission(SM326 saginaw 3 speed manua with rear add-on .70 overdrive ratio final drive unitl) was ordered in these trucks.
    Maybe possibly was 4.10 in later years such as 76 or so til 82(82 last year of the 12 bolt axle) but I dunno about that possibility.... 4.10 was mainly or only a 3/4 and 1 ton ratio.
    I feel you wil be going for aftermarket gear set to get 4. anything ratio in the 12 bolt
    just making notes
    good luck
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    my budy has a set. he needs to find a rear axle first though.
    PM him and ask his SN is Or2Play
    Grant
  4. NOT4SHW
    NOT4SHW Guest
    I have a complete matching set front 10 bolt and rear 12 bolt, complete axles both with 4.10 gears. If your interested I want $600 for both axles complete the rear also has new gears, arp bolts and auburn limited slip. Just the parts in the rear axle were $600 from 4wheelparts. New brakes front and rear 1 new caliper in front and both rear wheel cylinders are new.
    Thanks! www.gulfcoast4x4s.com
  5. The85k5
    Feb 22, 2001
    259
    Sunnyvale,Ca
    hmm well for one i live like 500 miles away from you! and i already have the front axle with the gears in it....its just the 12 bolt i picked up happened to have a chip in the tooth
    thanx anyways though!
  6. or2play
    or2play 1/2 ton status
    Feb 22, 2002
    657
    Yuma, Arizona
    I have a 12 bolt with 4.11 gears. I might be getting a 14 bolt very soon. When I do the 12 bolt will be up for sale. The gears are in great condition. I would perfer to sell the entire rear end, however I need to replace one axle shaft and bearing. So I may just end up sell the gears and whatever else I can strip off it.
  7. The85k5
    Feb 22, 2001
    259
    Sunnyvale,Ca
    sounds good....i already have the axle but if deside to strip it definitally keep me posted
    my e-mail is Krazyr82@aol.com
    i'm on ck5 alot though so i'll be around
