need 4x4 shifter pics
Discussion in 'The Garage' started by freeflow, Mar 23, 2006.
  1. freeflow
    freeflow 1/2 ton status
    Nov 6, 2004
    274
    alexandria, minnesota
    Ok everybody im gonna mount the 4x4 shifter and i need some pics of the location. Does it have 2 be in the perfect spot or can it be off by a lil bit? im gonna make my own rods to go from there to the transfer case.
    I should have taken measurements and pics of my last truck before i junked it haha.
    thanks
    brad
  2. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    what's wrong with the stock t-case shift location? are you adding gear boxes, or are you converting a 2wd truck? anyway, here's a pic of my stock 208 location.
  3. freeflow
    Nov 6, 2004
    274
    Thanks for the pics- yeah i couldnt remember if it was closer to the dash or closer to the seats.
    yeah i converted the burb from 2wd to 4x4:D
    brad
  4. RootBreaker
    Nov 29, 2001
    5,118
    173
    Williamstown, NJ USA
    what kind of xfer case you putting in?
    I have a setup that im going to ebay for a 208 like in that pic (minus pool ball :haha: )
  5. steve_kibbe
    steve_kibbe 1/2 ton status
    Feb 4, 2004
    2,895
    Spartanburg, SC
    You might want to go get a 4x4 center cover, it will already have the hole and mounting tabs:D
  6. RootBreaker
    Nov 29, 2001
    5,118
    173
    plus im not sure on subs but pickups.. the hump is smaller... lower profile on the 2wd and doesnt unbolt... I had to jigsaw mine out as I put a 2wd cab on.. and bolt my 4wd hump on
  7. steve_kibbe
    Feb 4, 2004
    2,895
    Spartanburg, SC
    Gotcha, never delt with a 2wd:D
  8. colbystephens
    Feb 24, 2005
    10,924
    20
    Oregon
    i wish i knew how to describe this more clearly, but perhaps you could draw a right triangle where the base of the triangle is the linear distance from where the shift lever goes into the t-case, and the leg perpendicular to the base is a representation of where the shift lever sits in 4lo. then you would know the distance from the t-case where you should start cutting. then remeasure this length at the 2wd setting, and you'll know how far to cut. just .02
  9. stus84
    stus84 1/2 ton status
    Mar 21, 2005
    109
    MN
    i read that three times and I now feel dumber than when I started. :doah:
