Need 7 inch slip for front shaft
Discussion in 'The Garage' started by garlicbreath, Aug 16, 2006.
  1. garlicbreath
    garlicbreath 1/2 ton status
    May 17, 2003
    1,136
    Denver
    I went to rausch creek this weekend and after doing my 52's, crossover, and furd towers on the 71, I pulled the front shaft apart twice. It is 27 inches collapsed and 32 extended, thats the measurements from yoke to yoke. I am running one tons and a 205 with cv's front and rear. My local driveline guy found a male slip with about 5 inches of splines, from a carrier bearing shaft but it won't leave enough splines engaged at full droop to survive a 400hp hillclimb. Thats when it tacoed beyond repair sunday, on that last bounce at the top where both front tires are off the ground and the full weight of the tires and axle pulls the driveline to it's max.
    Articulated it's just fine.
    I could put in a limiting strap, but where's the fun in that?
    Maybe one right in the center would work, but not limit articulation too much.
  2. Citizen Rider
    Citizen Rider 1/2 ton status
    May 5, 2005
    1,415
    Plano, Texas
    Square shaft??? 12"+ of slip
  3. garlicbreath
    May 17, 2003
    1,136
    Denver
    I don't like the idea of running a square shaft on the street just yet.
  4. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    you running flanges??
  5. garlicbreath
    May 17, 2003
    1,136
    Denver
    No flanges. Haven't converted to that. It has the standard CV at the case, and the slip at the D60
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    The why are you worried about it on the road?? Unlock the hubs and stick it in 2wd.
  7. Citizen Rider
    May 5, 2005
    1,415
    Plano, Texas
    Wont be using the front shaft in 2wd :D
