need a 205 shifter
Discussion in 'Parts & Trucks Wanted' started by mplogic, Aug 10, 2003.
  1. mplogic
    mplogic 1/2 ton status
    May 7, 2002
    263
    Phoenix, AZ
    Need a tcase shifter for a 205 going into my bro's 77 Jimmy. Don't know if the stock 203 bezel will work so I'd like to get the bezel, boot, all linkages and anything else I might need for this conversion.
    If you shoot me an offer, please include shipping to Scottsdale, AZ 85260.
    Thanks!
  2. Rolled
    Rolled 1/2 ton status
    Jun 16, 2002
    683
    Anchorage, Alaska
    How tough are they to pull? I spotted one the other day in a wrecking yard. It was a mid 70's 465/205. Might be too much trouble to get out though...
    I don't know much about 205/203's but the shifter *looked* the same from inside the truck. If they are the same, I know where a couple 203's are.
    I forget the name of the yard right now. I'll jog my memory if you want to go look at it.
  3. mplogic
    May 7, 2002
    263
    Phoenix, AZ
    Thanks for the offer but it's probably not worth pulling. Was hoping somone had one loose already laying around.
    Somone on the forum has one they can ship, was just checking to see if I could find it local first.
    Thanks!
    Tim
  4. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I agree. Its way too hot to pull it. I pulled both axle shafts out of that rig today. /forums/images/graemlins/angryfire.gif
    Anyways, it is still there and they want $20 for the shifter assembly. If you are interested, it is the yard directly south of Ecology Auto. I can't remember the name but it is on the same side of the street, just south of the tracks.
    Good Luck
  5. Rolled
    Jun 16, 2002
    683
    Anchorage, Alaska
    I forgot to mention - They just lowered their prices on several things. Including: Transfer cases for $57 /forums/images/graemlins/smile.gif If anybody needs a 205 out of a 73 with a 4 speed, here is your chance to get one cheap. There is also a couple 203's in there...
  6. mplogic
    May 7, 2002
    263
    Phoenix, AZ
    wow I should check 'em out.
    Thanks for the info.
  7. 70jimmy
    70jimmy 3/4 ton status Premium Member GMOTM Winner
    Mar 3, 2000
    5,962
    252
    Released from Pueblo, told I belong in Southpark
    If you still need the shifter and stuff either PM me or reply to this message. I just twin sticked mine and have shifter, shifter knob, As far as linkage goes I have the metal bar and stuff that connects to the shifter lever. I used the pins that go through the shifter rods though. Let me know. Its sitting on the bench in the garage. This all came out of my 70 Jimmy. Not sure if its the same or not. I also have the boot.
