need a 2wd box in AZ, can you help me??
Discussion in 'Rocky Mountain Region' started by supersize75, Nov 5, 2003.
  1. supersize75
    supersize75 1/2 ton status
    Sep 27, 2002
    2,638
    gilbert az......by Phoenix
    Trying to accuire the last 2 things for my cross over, need a box really bad /forums/images/graemlins/ears.gif
    Also posted in the wanted section /forums/images/graemlins/ears.gif
  2. juanblzer
    juanblzer 1/2 ton status
    Sep 12, 2001
    1,614
    9
    Chandler, Arizona
    If a used one can't be found...
    check out Bench Works steering systems in Scottsdale. The guy really knows his stuff and the price is right around what Autozone or others will charge.
    I have a 2wheel box but it's off a 89 gmc pickup i.e. inside frame mount (i believe)(can be used as a core?)
  3. 87GMCJimmy
    87GMCJimmy 1/2 ton status
    Nov 21, 2001
    582
    Phoenix, AZ
    Just a thought, you could pull the sector shaft out of it and see if it's the same as the 74-87 2wd's. It just might be and then we'd have found a new source for the 2wd shafts.
    If Shawn has the 4wd box you can put in the 2wd shaft in it for x-over. I don't know if he needs the entire box though.
    Mike
  4. supersize75
    Sep 27, 2002
    2,638
    I have a box but its leaking near the shaft and would rather get a whole box so I can tap it for hydro, or just tap the caps instead. /forums/images/graemlins/thinking.gif
