Need A 9" hydro ram!!!
Discussion in 'The Garage' started by CCRider, Mar 11, 2003.
  1. CCRider
    CCRider 1/2 ton status
    Jul 8, 2001
    314
    Charlotte North Carolina
    Need A 9\" hydro ram!!!
    I have exactly 9" of travel left to right and love the turning radius , and would like to NOT limit it with an 8" ram , does anyone know who makes a 1.5 or 1.75 dia 9" travel ram??? Thanks...........CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif
  2. willyswanter
    willyswanter 1/2 ton status GMOTM Winner
    Dec 24, 2000
    2,690
    Bakersfield, CA
    Re: Need A 9\" hydro ram!!!
    You can contact Matt of West Texas Off Road and see if his supplier has them. I believe he can get a bunch of different sizes for different applications...
  3. Leadfoot
    Nov 28, 2000
    3,112
    Western Massachusetts
    How did you get 9" of travel? Did you remove the stops? Or did you get it by using longer arms where the tie rod attaches. Reason I ask is the stops on the knuckles are there due to limitations with the u-joint in the knuckle. If you try to turn past the stops in 4WD, you will probably spit out a u-joint even under no stress. Just thought I would mention it as I don't know if that is what you are trying to do....
  4. Derf00
    Derf00 1/2 ton status
    Jul 25, 2000
    1,683
    Abilene, TX
    Good question. I have a D60 with the 8" ram and it will go stop to stop.
  5. CCRider
    Jul 8, 2001
    314
    Can anyone confirm the spitting out of a 1410 axle joint , with the stops removed ??? I figured if I can get 9" without the stops , I could use it , it turns an awesome radius!!!!as tight as a new tj with 38's!! i also thought about it spitting out the joint , but the angle is no more than a new tj , and only slightly more than a stock 44 . I know it will stress them the more angle you have on them , thats why I got the spicer forged joints and 35 spline outers to strengthen the beeeeotch up !! any more input??? if worse came to worse I would install the stops for wheeling and remove them for daily driving , parking lots are a breeze with the turning radius I have now!!!! I'd hate to give it up If I don't have to .................CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  6. jeffro
    jeffro 1/2 ton status
    Jul 2, 2002
    406
    Scurry, TX
    get a 10" cylinder and have a 1" stroke limiter put in.
  7. CCRider
    Jul 8, 2001
    314
    Who makes it and why wouldn't they make a 9" ram???.CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
  8. jeffro
    Jul 2, 2002
    406
    Scurry, TX
    Northern probably. 8's and 10's are cheap. Custom stuff isn't.
  9. TheLakeRat
    TheLakeRat 1/2 ton status
    Nov 29, 2001
    363
    San Angelo, Republic of Texas
    I can make you one for around 175, but there will probably be about a 1-2 week wait.
  10. CCRider
    Jul 8, 2001
    314
    Sounds reasonable matt , do you see any problems with the u-joint /steering angle issue from above ? I looked at it again and the u-joint doesn't hit itself or anything , and angle does'nt look too terrible. Thanks.........CC /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif /forums/images/graemlins/k5.gif /forums/images/graemlins/usaflag.gif
