Need a couple pics of brackets on a big block
Discussion in 'The Garage' started by Yukon Jack, Apr 17, 2003.
  1. Yukon Jack
    Yukon Jack 1/2 ton status
    Jul 25, 2002
    1,984
    Rose Hill, KS
    I'm about ready to put accessories back on a 1989 454. I am not positive about which brackets my power steering uses and exactly where they bolt up on the block. It had A/C but I'm not using that but I'm not sure if the power steering brackets tied into the A/C brackets. Also changing to headers but I don't think that matters with the power steering brackets.
    Anyway, could someone post a couple pics of their power steering bracket setup on a big block of this similar era. Thanks!
  2. prjt_blzr
    prjt_blzr 1/2 ton status
    Mar 4, 2001
    352
    COS, CO
    GM was really confused on which brackets to use on the '89 454. It depended on the final vehicle application and options. Some trucks used "V" belts, some used serpentine belts and some (like mine) used a mix. Assuming that your PS uses a "V" belt it should mount on the lower left hand side of the block (drivers side). The first bracket bolts to the back of the pump and to the front of the block the second bracket bolts to the front of the pump and to a 1/2" bolt on the water pump. I don't have access to a digital camera but I hope my description helps.
    Mike
  3. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Mine uses the mixture of belts also, it's the old cab body style so I think that is the reason. I'll do some looking at my brackets some more and see if anyone else has a pic by chance. It probably will make sense now.
  4. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
  5. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Thanks, mine brackets I think are a bit different but that helps.
  6. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    The pictures that Harry posted will be a good start. If you have the mixture of belts then you should have the following.
    The PS pump is located in the lower left hand side on its own brackets. You should have a three groove pulley. The deepest groove is dedicated to the PS pump and crank. You should also have a remote reservoir that bolts to the altenator bracket.
    The AC sits above the PS pump on several brackets. The middle groove on the PS pump and crank is shared with the PS pump, AC and water pump.
    The altenator sits on the top right hand side on two brackets. It uses a serpentine belt that is shared with the crank, water pump, and AIR system.
    The AIR pump sits under the altenator using the same two brackets. You need this pump if you have emmissions inspections.
    If you don't use the AC then you can run the two "V" belts for the PS pump or the use the center belt for the PS pump and water pump for some redundancy if a belt breaks.
    Good luck,
    Mike
  7. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Thanks for the detailed info. I should have taken better pics before disassembly - lesson learned.
    So from you description the A/C brackets are completely separate from the power steering brackets - that is what I am hoping.
  8. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    IIRC yes. I will verify tonight.
    Mike
  9. prjt_blzr
    Mar 4, 2001
    352
    COS, CO
    I checked on the brackets last night. The PS pump does not use any of the AC brackets or bolt holes. It is a three piece bracket not two piece. The rear bracket bolts to the face of the block and the there is another small bracket that goes to side of the block under the #1 plug. It bolts to the removable stud on the rear of the PS pump.
    Good luck,
    Mike
  10. Yukon Jack
    Jul 25, 2002
    1,984
    Rose Hill, KS
    Thanks a lot for the info, that will help me and sweet that it doesn't tie into the a/c. This will save me some head scratching for sure. /forums/images/graemlins/thumb.gif
