need a couple things!
Discussion in 'Parts & Trucks Wanted' started by jjlaughner, Jun 19, 2004.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    I got the spring plates... need 2" tapered blocks and LONG 14bolt UBOLTs if anyone has some cheap. Otherwise I'll hit the tractor supply for some HD ubolts.
  2. bigchief427
    bigchief427 Registered Member
    Dec 7, 2003
    35
    martinsville indiana usa
    Re: need 14bolt ubolts, blocks and spring plates
    How long of ubolts?
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    I actually need two sets (2 14bolt axles) one for a stock spring pack and the other to fit a 2" block plus springs. No idea how long total /forums/images/graemlins/dunno.gif
  4. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    u-bolt lengths
    axle tube diameter + spring pack thickness + 2" = u-bolt inside length
    for the u-bolts with the blocks, just add in the height of the block /forums/images/graemlins/thumb.gif
  5. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    ok so 14bolt measures 4.25 (bottom of axle tube to top of the spring pad), both truck spring packs measure 2.5" plus the 2" plus the 2" for the block
    so one set would need to be 8.75 round up to 9"
    the other set would need to be 11"
    Need 4 - 14bolt spring plates
    .....4 - 14bolt 9" ubolts
    .....4 - 14bolt 11" ubolts
    and a set (2) 2" tappered blocks
    /forums/images/graemlins/waytogo.gif /forums/images/graemlins/ears.gif /forums/images/graemlins/1zhelp.gif
  6. OL14BLAZ
    OL14BLAZ 1/2 ton status
    Aug 14, 2002
    1,815
    TEXAS, USA
    I have a pr of 14 bolt spring plates. 10.00 dollars plus the ride.
    If you want them send me a pm or post here. /forums/images/graemlins/peace.gif
  7. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    sending PM /forums/images/graemlins/waytogo.gif
  8. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    top again... I got 2 set of springs plates... still need 2" tapered blocks
  9. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
