Need a DRAC
Discussion in 'Parts & Trucks Wanted' started by hidesertwheelin, Feb 20, 2007.
  1. hidesertwheelin
    hidesertwheelin 1/2 ton status Premium Member
    Nov 13, 2004
    782
    4
    Hesperia, CA
    I need a DRAC for my 1990 Suburban. Hopefully one with the DIP switch alreadt installed, cause I don't have a soldering iron :D
  2. sweetk30
    Nov 1, 2004
    25,549
    543
    horseheads , ny 14845
    if no one pipes up i can di it for ya. just give me a few days to go to the local yard and radio shack. i have done it before and he loved both of them and thay worked perfectly.
  3. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    What is a DRAC? In the computer world that is a Dell Remote Access Card.
  4. dyeager535
    26,980
    I've got one already setup for 3.73 and 35's, any chance that'd be the ratio you need?
    I'd have to pull it apart to see if there are DIP switches (I bought it from someone that had it professionally calibrated) but either way, I'll part with it.
  5. BKinzey
    BKinzey 1/2 ton status
    Jan 13, 2006
    3,145
    Hollywierd, CA
    Yeah? What is a DRAC????:confused:
  6. sweetk30
    Nov 1, 2004
    25,549
    543
    if you have electric spedo unit you need a drac.
    drac = tranny or tcase speed sensor output in to drac box. tire size and axle ratio in the mix threw the jumpers in stock form make correct spedo output.
    so if you change your tires or axle ratio or both you need to rework the box. there is a mod to do to these. all you do is get a 7 pin dip switch setup or 8 pin if need be. then remove the stock jumpers ad the switch unit in place.
    go to the chart and find out jumper code to turn on and off for correct signal.
    look here. my work in the past. http://www.coloradok5.com/forums/showthread.php?t=188869&highlight=drac
