need a drive shaft
Discussion in 'Parts & Trucks Wanted' started by aealliarmy, Apr 29, 2005.
  1. aealliarmy
    aealliarmy Registered Member
    Mar 3, 2005
    75
    Newport News, Va
    need a stock drive shaft for an '88 K-5. all the info i can get is appriciated. thanks
  2. novapain
    novapain Registered Member
    Nov 23, 2002
    20
    Lawrence, Kansas
    Front or rear? What axle? What tcase? A bit more info please.
    I have a front that is for a NP203 to Dana44/10bolt.
    Let me know if that is what you need.
  3. aealliarmy
    Mar 3, 2005
    75
    Newport News, Va
    i need the rear drive shaft for a 10 bolt. not sure which t-case it is.
  4. novapain
    Nov 23, 2002
    20
    Lawrence, Kansas
    Sorry I couldn't help you. You will need to know what tcase it is in order to get the right length DS. I am not too familiar with the newer stuff but it could be a 208 unless it was swapped out. Plus you will need to know if it is a slip yoke or fixed yoke. You might try www.drivetrain.com or www.offroaddesign.com for some info to help identify what you have. Or go to http://www.dennysdriveshaft.com/html/how_to_measure.html and it will help you measure for a new shaft.
    Hope this helps,
    Phil
  5. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    as long as you get one from a 81 and newer it will be the same length. but if you have a factory sm465, it will have the big 1350 ujoints. if a 700r4 it will have s44 (1310) ujoints.
  6. only 31s
    only 31s 1/2 ton status
    Oct 5, 2004
    224
    mass
    i have 2
    did u find one yet .I have 2 one is the stock one 29.5from joint to joint ,from a 241 to a 10 bolt. the other is 31.5 from joint to joint,from 241 to 10 boltw/a 4'' lift it is also a one ton set up {you can get a conv joint to the rear axle for 15 bucks at napa} :)
