need a driveshaft measurement...those with doublers
Discussion in 'The Garage' started by muddybuddy, Sep 21, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    found a shaft on another forum that might fit the bill for my new front driveshaft after the doubler is built. what i would like to know is, what is the length of your front driveshaft on your doubler setup? i would like to have a general idea so i know if this one would likely work or not. thanks
  2. daleearnhardt01
    daleearnhardt01 1/2 ton status
    Aug 29, 2002
    3,223
    Richmond, VA
    You know you need to find somebody that is real close to your lift and stuff otherwise its not even gonna be close...
  3. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i know, i guess what i should have said was, how much longer is it than the shaft you were running before installing it? i know its longer but i forget how much longer it makes it.
  4. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    it all depends on the lift. although the tcase may be 4" farther back (not sure if that the number or not, just throwing one out there) the shaft will may need to be more than 4" longer because of the angle
  5. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    yea what im trying to figure out is how much farther back the yoke/flange is. i thought it was like 4" but i dont remember.
    i know the gen2 doubler is 3" shorter than the gen1 from ORD
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    I once tried to figure out what i would need for a front driveshaft when going from a 700R4/241 to a 700R4/203/205 and from as far as i could tell the front shaft was going to be the exact same length.
