Need a favor... can't find my Haynes manual
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by MudFrog, Nov 10, 2001.
  1. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    Need a favor... can\'t find my Haynes manual
    Can someone tell me what ft. lbs. torque needs to be applied to the lock nuts or whatever they are called, that are located inside of the hub. They are the little nuts with the 4 cut outs and need the special tool. I need to know what the first one (furthest from the diff) and the second (closest to the diff) are torqued to. Thanks.
    89 K5 Silverado, 4", 33's, 3/4 ton axles
    <a target="_blank" href=http://mudfrog.rockcrawler.com>http://mudfrog.rockcrawler.com</a>
  2. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Re: Need a favor... can\'t find my Haynes manual
    <a target="_blank" href=http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=118261&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1>http://coloradok5.com/forums/showflat.php?Cat=&amp;Board=blazer4x4&amp;Number=118261&amp;page=&amp;view=&amp;sb=&amp;o=&amp;vc=1</a>
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  3. MudFrog
    Feb 23, 2000
    3,236
    Daleville, Va
    Cool...thanks!
