need a few tips on gettin a few more parts
Discussion in 'The Garage' started by surpip, Aug 4, 2004.
  1. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    /forums/images/graemlins/1zhelp.gifi need the vent tubes for the 14ff and the 60, the ones that actually attach to the axels, cheap place to get the 14ff longer wheel studs, front spring bolts, not the shakle side,(i was thininking of getting them from ORD so i can get the greaseable ones) and the banjo bolts for the 60 front brakes, thanks alot for all the help,
    dale
  2. GMCLegacy
    GMCLegacy 1/2 ton status
    Jan 24, 2002
    620
    Grand Haven, MI
    i used fuel line for my vent tubes, buy lots of it, and run it as high as you can.
    banjo bolts you may be able to scroung the junkyards for 2wd 1 tons.
    id just buy new wheel studs, it gets expensive, but not worth your time messing with tearing one apart at a junkyard.
  3. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    i dont need the vent tubes, i need the metal part that goes in the axel
  4. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    I was looking at my parts store today and had a brilliant idea . When I do mine I am going to tap the hole the vent tube goes in , attach a brass fitting and run from my store stock some stainless braided icemaker line ( I go from 12 inches long to 122 inches long ) with threaded ends on each side . This will go up through my floor drain holes ( enlarged ) and will EVENTUALLY thread onto my cage to vent as high as possible /forums/images/graemlins/thumb.gif
  5. surpip
    surpip 1 ton status
    Apr 7, 2004
    10,877
    sacramento ca
    good idea but i need somthing sooner, i dont have time to do that
  6. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Banjo bolts in the Help! section at your local parts store, look on the back of the package for a 10mm one and you're good to go. Should be in stock at the store for $3.50 or less each.
