Need a locker for a 12 bolt OR a 14 bolt in AZ.
Discussion in 'Parts & Trucks Wanted' started by Greenblazer-AZ, Mar 20, 2002.
  1. Greenblazer-AZ
    Greenblazer-AZ 1/2 ton status
    Jan 4, 2002
    770
    Chandler, AZ
    I currently have a 12 bolt in my rig and I have a '73 3/4 ton parts truck with 14 bolt / Dana 44 that I'm planning to swap. The '73 has a good body, and bed that I plan to sell. I'm going on a run on the weekend of April 13th and need to lock one of my axles by then.
  2. DesertDueler
    DesertDueler 1/2 ton status
    May 23, 2001
    3,106
    Phoenix, AZ
    Weld up the front since you plan on swapping axles anyways.
  3. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    hell man, weld them both up and run half ton for the weekend.
    maybe i will be done moving by then and try to make it up there.
    Grant
  4. Greenblazer-AZ
    Jan 4, 2002
    770
    Chandler, AZ
    Hhmmmm, tempting, but I do have to drive this thing to work. I am considering welding the rear, but both would make it too hard to steer since my t-case linkage is still messed up. Having to crawl under the truck to lock or unlock the front wheel drive every time I wanted to turn would be a pain. Hey Dan how long did your welded 12 bolt last?
  5. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    I mini spooled mine, and it lasted for one hard run and a few pretty easy runs, then it came apart.
  6. Greenblazer-AZ
    Jan 4, 2002
    770
    Chandler, AZ
    WHere did it break? Was it the spool it self? Take a guess on how many miles you drove it before breakage.
  7. DesertDueler
    May 23, 2001
    3,106
    Phoenix, AZ
    The spool broke itself. I would say less than 200 miles. I was locked front and rear at the time, so that puts less stress on the rear axle.
