Need a measurement from anyone with an 87 GM
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Eric M., Mar 20, 2004.
  1. Eric M.
    Eric M. 1/2 ton status
    Dec 10, 2001
    2,118
    Oakland, CA
    /forums/images/graemlins/1zhelp.gifI need the measurement of the stock front shackle on an 87 GM 4x4. This is the shackle located at the rear of the FRONT leaf spring. Center of top mounting hole to center of bottom mounting hole. It should be either 4" or 4 1/2".
    Thanks in advance. /forums/images/graemlins/waytogo.gif
    Eric M.
  2. heavy4x4
    heavy4x4 1/2 ton status
    Aug 28, 2002
    3,270
    Delafield, Wisconsin
    4" stock shackles
    4.5" ORD HD shackles
  3. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    4" stock shackles
    Is that off an 87 or your 90 Burb? My 91 Burb measures 4.5".
    Thanks,
    Eric M.
  4. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    From the ORD site:
    "In 1988 the factory introduced a longer front shackle on K5's, Suburbans and some 1-ton trucks. These shackles are the same length as our HD shackles."
    Geez, had the answer in front of me the whole time ....
    Eric M.
  5. 4xrick
    4xrick 1/2 ton status
    Sep 14, 2003
    1,102
    kirkland Wa
    my 88 is 4 stock i just measured
  6. Eric M.
    Dec 10, 2001
    2,118
    Oakland, CA
    Hmmmmm, the plot thickens ...
    Anyone else? There has to be some rhyme and reason to all this.
    Eric M.
  7. rooferbret
    rooferbret 1/2 ton status
    Dec 26, 2003
    265
    Sacramento,CA
    my 87 is 4" also. just checked for ya.
  8. heavy4x4
    Aug 28, 2002
    3,270
    4" stock shackles
    Thanks,
    Eric M.
    From the ORD site:
    Eric M.
    Well, I didn't actually go out and measure my stock shackles. I remember reading at one point that ORD HD shackles (what I have now) are 4.5" and that they are .5" longer. Sooo...I made the assumption that my stockers were 4". That may not be the case now...if I remember, I'll go out and measure them and post up what the stockers on my '90 suburban were.
