Need a New Distributor
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1986Blazer, Jun 15, 2001.
  1. 1986Blazer
    1986Blazer 1/2 ton status
    Jun 13, 2001
    511
    Key West, FL - Southernmost Point
    Everyone - I just fixed the timing problem, thanks Grim-Reaper. During the "fix" I also found out my Distributor is loose so I need to fix it. NAPA has a rebuilt for $127.00 but there is no telling who made it. I want to instead order a good one from JEGS or SUMMIT. I like the specs of the Mallory UNILITE Vacuum advance. Does anyone have this installed????
    If so, it appears to me it requires an external coil - is this correct.
    Also, does anyone recommend a good replacement HEI distributor for a basically stock 350 for an 85 engine?
    Cost is a factor - I'm not looking to spend $300.00 but I'm not shy about paying for quality.
  2. tRustyK5
    Jul 23, 2000
    36,184
    1,393
    E-town baby!
    For a "basically stock" 350 I'd stick with a "basically stock" replacement HEI distributor...its very reliable up to about 6000 RPM which is well past the usable RPM limit for a stock 350. Replacement parts will be easy to buy and it won't set you back a kajillion bucks to buy.
    Just my two cents
    Rene
  3. denver75k5
    denver75k5 1/2 ton status
    May 15, 2001
    1,017
    Somewhere In The Woods
    Hey , I have a " Summit" Hei and it kicks butt!
    Jeep Thing,? Ya i ran over one!
  4. xnoahx
    xnoahx 1/2 ton status
    Oct 12, 2000
    817
    Ventura, CA 93004
    I thought about getting a summit HEI a while ago but i instead just got a used one for $30. It worked a lot better than my pionts. Pertronix also sells a very nice HEI from what ive read in Car Craft for $220(summit.) It has everything you could ever want for your HEI.
    Check out my 73 K5 http://members.theglobe.com/xnoahx/73k5.htm
