Need a new starter ... and recommendations
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by spearchucker, Jan 21, 2004.
  1. spearchucker
    spearchucker 1/2 ton status
    Nov 17, 2003
    1,556
    Bay area, CA
    My starter has served a good life for about 8 yrs. Today my Blazer wouldn't start, actually the solenoid wasn't energizing. I had to tap on the solenoid a few times and then it started up. I know that I only need to replace the solenoid but since the starter is so old I decided to replace the entire unit. My question is how do I know how many teeth my flywheel has? It's an 89 Blazer with a 350 tbi mated to a 700r4. I was thinking about getting one of those high torque starters but would like your opinion on them. Also what brand would you recommend?
    TIA
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    Re: Need a new start ... and recommendations
    167 or 168 is what i believe the number is /forums/images/graemlins/thumb.gif
  3. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I went with a stock style replacement from O'Reillys. Lifetime warranty. Ran me about $40. No problems out of it and its been on the truck for about a year. I'm pretty sure its a 168 tooth flywheel too. Someone will chime in that know for sure though.
    Kris
  4. tarussell
    tarussell 1/2 ton status
    Dec 28, 2002
    1,354
    Bagdad , FL
    168 it is ... /forums/images/graemlins/thumb.gif
  5. spearchucker
    Nov 17, 2003
    1,556
    Bay area, CA
    Thanks for the replies. /forums/images/graemlins/thumb.gif
    Any comments on the high torque starters? /forums/images/graemlins/ears.gif
  6. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    If you are running headers look into a remote solinoid set up. It will help keep the heat fade to a minimum. I usually equate a hi torque with a high compression engine.
  7. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    If there is a local starter rebuilding shop, check them out befor you shell out your hard earned cash at the parts house.
  8. dyeager535
    26,979
    Apparently (from a magazine test I read awhile back) the high torque starters can "cure" the header heat soak issue as well, so along with a new starter, you could potentially avoid putting in new wiring and a solenoid. FWIW.
  9. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Get a AC Delco, they are lifetime warranty also. I personally wont run that parts store crap on my truck. Maybe its because I work at the dealer and see AC Delco all the time but it seems that the Delco stuff fits better and lasts longer.
  10. doctor4x4
    doctor4x4 1/2 ton status
    Jan 22, 2002
    1,450
    Los Angeles
    Well i agree for a stock replacement ya cant beet the acdelco
    but if ya can afford it i do recomend the high torque starter with remote silonoide also
    for the following reason's
    1 less weight = less likly to break starter bolt or crack nose cone or Fup *# the engine block were the bolts go in
    2. long life expentency
    3 header clearence and heat resistance
    4. less amps needed to turn it over i believe
    5. spins motor faster
    6. if ya do beef up your motor ya still got the muscle to spin it
    7, remote sylanoid = fixes problem of heat also and biggest advantage gets those starter wires away from heat and were ya can get to em if somthing does go wrong every body in our little club has converted to this
    Guess that its 4 now id give more but im sick of typing :-)
    R
  11. dyeager535
    26,979
    I didn't think the block breaking issue had anything to do with weight. I thought everyone cracked the block while tightening them, and if anything, the force on the block is greater when the starter is trying to rotate the flywheel/flexplate. Dunno for sure, just seems from all the people I've heard of cracking blocks in that area, it was from tightening the bolts up.
    As to AC Delco, well, maybe the starters, but the last battery cable I bought from AC Delco had "Made in Taiwan" right on the package, and was nowhere near the quality and construction of the 1985 piece it was SUPPOSED to replace. You wouldn't think you could make a battery cable cheaper, but Delco figured out a way.
  12. MA87K5
    MA87K5 1/2 ton status
    Apr 6, 2000
    558
    Chicopee, Ma 01020
    I bought a starter from Autozone about 5 years ago it came with a lifetime warranty for around $30. plus core. I have had no problems with it what so ever. All the starters that I bought from them I never had a problem. I have one that turns my 383 Camaro, and that one is even older. (when autozone was autopalace) If heat is the issue then go with a mini starter, but if not then go with a reman from autozone. The GM reman starters are high torque also. You pay for the name for most AC-Delco parts. As long as the quality, reliability, fit and price are good then who cares who made it. Everyone has their own opinion, this is mine.
