Need a new tow vehicle!
Discussion in 'The Garage' started by pismorat, Apr 10, 2005.
  1. pismorat
    pismorat 1/2 ton status
    Oct 29, 2002
    540
    California
    Alright, we've got a '99 4x4 Burb with a 454 that is an awesome truck, but it can't pull our 26' Weekend Warrior for sh!t. It does good on flat or downhill, but if we hit a hill it slows way down. What is the best 4x4 tow vehilce (diesel I am assuming) for a family and needs lots of room? Is Chevy ever going to put a Duramax in a Burban?!?! Thanks for your opinions. :truck:
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    You may want to consider re-gearing it. Most came with 3.73. Maybe its time for 4.10 or 4.56?
    I *really* like my aging Burb... I was hoping to get into a newer one, or even an Excursion - but the $$$$$ - OMFG! You may want to consider a crewcab and get a nice cap instead.
  3. pismorat
    Oct 29, 2002
    540
    California
    Yeah, it has 3.73's and 33" tires, but would that really help get it towing uphill better? We still want the "decent" :grin: mileage and able to use it a a DD.
  4. Thunder
    Thunder 3/4 ton status
    Jul 20, 2000
    8,946
    Northeast Nevada
    Re gear would be cheaper than a new truck. 3.73 and 33s = equal about a 3.40 gear ratio. Not exactly a great towing gear.
    A buddy of mine has a 5th wheel about the same size as your trailer. He only has a 6 L in his 3500. It has 4.10 ratio. It tows his 5th wheel pretty good in the hills.
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    Changing from a stock 245/75R16 to 33" has already effectively knocked back your 3.73 axle ratio to around 3.4-3.5 range. That's typically not the kind of gearing you would tow a load such as yours with.
    My 2 cents.
  6. Pookster
    Pookster 1/2 ton status
    Nov 21, 2000
    3,195
    NYC, NY, USA
    run some really low profile tires. It will look odd, but you'd be surprised by the effective torque gain.
  7. Jonny-K5
    Jonny-K5 1/2 ton status
    May 27, 2003
    1,654
    SoCal
    what would be best is if you could borrow a set of stock sized rims/tires or lowpros from a buddy and try towing with it. if it changes your mind about towing with your truck, then you might want to invest in a gearswap if it still sucks, then the gear swap isnt really gonna help.
    if you decide on a new tow rig, i'd go with a diesel crew cab w/ shell. any of the big three would be a good choice.
