Need a pic of a front chevy Dana 60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by blazin72, Feb 3, 2001.
  1. blazin72
    blazin72 1/2 ton status
    Oct 24, 2000
    279
    Oklahoma
    I was wondering if anyone had a pic of a dana 60 front diff.
    And also how can you tell if you found one at the salvage yard.
    I think i ran across one but want to make sure.
    Blazin 72
    Blazin 72
  2. CK5
    May 19, 1999
    21,623
    701
    CO
    There is an axle guide in the tech section.
    Steve
    Mall-Running poseur 4x4 with curb-feelers
  3. blazin72
    Oct 24, 2000
    279
    Oklahoma
    Does it show a pic of a front dana 60?
    Blazin 72
  4. It looks like a d44 only bigger,they're realy hard to tell apart other than the big diff in size.
  5. titanic
    titanic 1/2 ton status
    Mar 27, 2000
    498
    north alabama(huntsville)
    I sent you a picture.
  6. JUNKYARDDOG
    JUNKYARDDOG Registered Member
    Feb 3, 2001
    7
    Kinderhook NY
    HEY A QUICK WAY TO TELL IF ITS A DANA 60 IS IF THE FRONT END HAS RECTANGLE COVERS WHERE THE BALLJOINT WOULD USUALLY GO. THEY HAVE KING PINS WITH BUSHINGS. LOOKS TOTALY DIFFERENT!
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    Take a look at the webbing around the cover. On the right hand side on the bottom are cast numbers protruding out. They say 60 for the D60 and 44 for the D44. Another way to check is, look on the pumpkin (passenger side) and inspect the spring pad. There should be two holes in the cast part of the pumpkin. This is where the two studs, or bolts, go to hold down the u-bolt plate. A D60 only uses 3 u-bolts. Last, check the knuckles. Each top and bottom of the knuckle plates are held by 4 bolts. This cant be confused with a D44 which uses 1 big nut to hold the ball joint together. The plates on the D60 knuckles are rectangle shaped.
  8. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    grab one end.And pick it up if you feel something break in your back it probably a 60.
  9. blazin72
    Oct 24, 2000
    279
    Oklahoma
    for all the help guys
    I didnt think it was a dana 60 and now I am sure.
    I am curious now though.
    What other 8 lug front differentials was used on Chevy I would say in the mid 80's I thought it was chalked for reference to be a 85.
    Not sure though.
    It kind of looks like a ten bolt. But I didnt think they made one of those in a 8 lug.
    Oh well I guess it doesnt matter now.
    Blazin72
    Blazin 72
  10. Bigd
    Bigd 1/2 ton status
    Apr 3, 2000
    399
    Co,Colorado Springs
    I think in '85 if it's not a dn60 it would be a 8-lug 10 bolt.thats what they used in 3/4 ton trucks.
  11. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    I am looking into an 84 k30 for parts would it have a 60.
    Happy Trails
    Wayne
