Need a PTO box for SM465 or pictures of one.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by burbBoy, Jan 18, 2003.
  1. burbBoy
    burbBoy 1/2 ton status
    Feb 4, 2002
    358
    WI
    Looking for a PTO box for a sm465 to run my winch. I found some in the junk yard buut i have no clue what they fit on. So some pictures or part numbers would be helpful if you have em. Thanks
  2. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    you found some in the junk yard?
    like how many?
    i am looking for one if they are the right ones. i dont know what the right ones look like though....
    Grant
  3. 70~K5
    70~K5 1/2 ton status
    Apr 13, 2002
    2,032
    sillycon valley
    Ask MJ or MG the canuc that everyone loves to hate, he knows all about these. /forums/images/graemlins/thumb.gif
  4. Diesel Dan
    Diesel Dan 1/2 ton status
    Feb 27, 2002
    798
    Warren, Ohio
    Why don't you run it off of the t-case?
    That is where I had mine mounted. The gears are cut oppisite of each other from a '205 Vs '203/SM465 application. So a box off a 203 will fit a SM465.
    Advantage to using the tcase mount is you'll get 4 speeds in one direction 1 in the other. All depends on how you spool the cable.
    Part #s will only do so much, there are so many different styles available. IF you mount to the SM465 you will need to find a PTO box that has a reverse in it. The counter gear shaft in the trans only goes in one direction. If you mount to the tcase a single speed PTO box works just fine, use reverse in the trans to unspool.
    I'll see if I can get a pic of the PTO box I have.
  5. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    Diesel Dan that's a great idea. I hadn't thought about using forward and reverse to control the direction of the winch. /forums/images/graemlins/thumb.gif
  6. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    Here is a link to some pics I took tonight. PTO pics
  7. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Link does not work
  8. Diesel Dan
    Feb 27, 2002
    798
    Warren, Ohio
    OK, delelted all my cookies and then it wouldn't let me see the page. Will work on the link.
    PTO box mounting flange, mounting flange
    PTO box, PTO box
  9. cegusman
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    Question about installing the pto box, Do you just pull off the pto cover and bolt on the box, or do you have set it up like a ring and pinion (with the corret backlash or something like that? I can see the pics now thanks
  10. 70~K5
    Apr 13, 2002
    2,032
    sillycon valley
    When installing a PTO you have to set the backlash. To do this you use different thickness of gaskets(shims).
