Need a quick answer - D60 kingpin spring length
Discussion in 'The Garage' started by Can Can, Jul 4, 2006.
  1. Can Can
    15,552
    136
    Cochrane, Alberta, Canada
    I'm leaving in about 15 minutes, and was hoping one of you could possibly tell me the approximate length of a D60 kingpin spring when it's just sitting, with no load on it.
    Anyone?
  2. Can Can
    15,552
    136
    One more quick question:
    The only 1/2" fender washers I could find were approximately one and a half inches across. I was under the impression they should be more like 2" to work properly.
    Will the 1 1/2" ones work?:dunno:
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    man you can get new springs for 8-10 bucks. and 95% of the ones i have replaced are warped to one side when standing flat by them selves. also get new bushings. almost every 60 i have been in eats the one side bushing compared to the other side.
  4. Can Can
    15,552
    136
    Will an average podunk parts store stock these, or are they generally only found at dealerships, etc....???
  5. sweetk30
    Nov 1, 2004
    25,552
    546
  6. Can Can
    15,552
    136
    Yeah, I know ORD sells the parts, but I'm going out to my property and was hoping to deal with this little repair in the next day or two. The closest town is about half an hour away, but they have a few parts stores and a GM dealership........
  7. sweetk30
    Nov 1, 2004
    25,552
    546
    also how is the condition of the ds studs and nuts. in the rust belt hear i need to order new on just about every one i do.
  8. Can Can
    15,552
    136
    This is on the V3500, which has absolutely zero rust, which is quite a change for me. The studs and nuts are in beauty shape, brother!!! :thumb:
  9. sweetk30
    Nov 1, 2004
    25,552
    546
    stealer ship around hear need to order them and 3 times the price.
    best soak the stuff with pb blaster and so on. then get new stuff and do next time. if thay are over 6-7 years old thay need changeing.
    why are you asking this? did you get the death shakes? feals like axle is coming out from under the truck. try that with 38" tires and have never had that happen and you want to crap your pants. :wink1:
  10. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    in my experience, parts stores and dealerships only carry those items in bulk. IE: 10/pgk or more....
    I would use the 2" fender washers because the smaller ones can walk around in the cap and cause damage to the bushing over time.
    Call Highonda and get a quote for the parts you need.
  11. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    Paul...still around? I've got a cap off of my D60 in the garage and could have that baby measured in a second or two if you still need it...
