need a radiator hose quick fix
Discussion in 'The Garage' started by johnnieg, Nov 17, 2003.
  1. johnnieg
    johnnieg 1/2 ton status
    Nov 10, 2002
    130
    CSU, Ft. Collins, CO
    My lower radiator hose is leaking where it clamps to the water pump. All the hoses are to be replaced within the next 1000 miles. What can I do for a quick fix to stop it from leaking without having to replace the hose? It is only leaking at operating temp.
  2. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Are you sure it's the hose leaking? There's a weep hole in the bottom of the water pump that will dribble coolant down that way when the seal in the pump begins to fail. /forums/images/graemlins/frown.gif
  3. Confedneck
    Confedneck 3/4 ton status
    Nov 1, 2002
    5,236
    Lehigh Acres, Florida
    the only fix for a leaky hose is to replace it, hoses are generally inexpensive, i wouldnt risk a fix like duct tape or anything on an 8 dollar hose that could leave me stranded..
  4. justhorsinaround
    justhorsinaround 3/4 ton status
    Sep 16, 2003
    6,798
    Northerish Phoenix, Az
    If it's not the weep hole (I made this mistake once thinkin it was the hose) what I did once when stranded was cut the hose a little short and then reattach the hose. Was a quick fix to get home. If truth be told though, it's still the fix even though I have a new hose. Just keep forgettin to put the new one on. /forums/images/graemlins/eek.gif /forums/images/graemlins/rolleyes.gif Good luck to ya.
    Allan
