Need a rear disk brake caliper (actually the pad) bracket
Discussion in 'Parts & Trucks Wanted' started by jjlaughner, Aug 12, 2005.
  1. jjlaughner
    jjlaughner 3/4 ton status
    Jan 12, 2001
    7,406
    Indiana
    2000 ZR2 Blazer, rear disks, had one of the slip/guide pins break off in the pad mounting bracket, GM wants $60 for one and $18 for the pins... Anyone have a 2000ish parts truck with rear disks?
    Need at least one bracket and 2 pins
    Got to save some cash at this point, I just dropped dough on 4 rotors, 2 sets of ceramic pads, emergency brake shoe and all the other little oddball pieces and parts, the stuff I need now has to be ordered and is salty... Help me out here!
  2. sweetk30
    Nov 1, 2004
    25,544
    539
    horseheads , ny 14845
    i got them out easy. if nub is sticking out weld nut to it. then heat the bracket red hot. and trist the nut left to right. it will come out. comon problem. and slides are in the hardware slide kit form parts stores. good luck
  3. jjlaughner
    Jan 12, 2001
    7,406
    Indiana
    thanks but heating it was not a good idea! not for us the first time...
    http://coloradok5.com/forums/showthread.php?t=146411
    I got everything put back together so scrap the wanted brake bracket...
    I could use a drivers side window switch panel there on the door though
